DIY: Oil Change 2014+ IS350 w/ pics
Old 07-10-15, 05:52 PM
  #31
Dark9t316
Dark9t316's Avatar
For me, i used the dedicated jack point behind the oil pan, the crushing was the rail against the jack stands. I didn't even release the jack all the way. I can't imagine what kind of damage could've happened...
Old 07-11-15, 09:59 AM
  #32
CF1LUV
CF1LUV's Avatar
Geez, you should post a pic of the damage if you have the time.
Old 07-13-15, 08:06 AM
  #33
Dark9t316
Dark9t316's Avatar
I'll try to take a pic bro when i get the chance. Basically if you look at the railing, you will see that it's built with 2 rows to metal plates joined together by few welding points. The inner plate sits higher than the other, and that's the plate that bent outwards since the pressure rested mainly on that plate.
Old 07-13-15, 08:42 PM
  #34
alpha12
alpha12's Avatar
Took mine to the Toyota dealership, was 63.02 OTD, Lexus was charging 139.99
Old 07-13-15, 10:03 PM
  #35
gmanusmc
gmanusmc's Avatar
That's a good way to go, especially if they use TGMO 0w20. Most Lexus dealers really do overcharge for oil changes.
Old 07-14-15, 06:38 PM
  #36
toeknee88
toeknee88's Avatar
Nice write-up!
Old 08-07-15, 10:58 AM
  #37
altezzza
altezzza's Avatar
thanks
Originally Posted by toeknee88
Nice write-up!
Old 08-12-15, 05:33 PM
  #38
Monoshock
Monoshock's Avatar
Default Rhino ramps, filter drain tube answers
Rhino ramps work great. Bought them after reading of difficulty with jacks because of low clearance. Good to have a partner watching the first time, just to ensure positioning.
350 filter does not have the drain feature, so you don't use the tube that comes with the filter.
Old 08-18-15, 11:28 AM
  #39
evident
evident's Avatar
Just want to also confirm that Rhino Ramps will work on this car in stock height, as I put mine on the ramps last week.
Old 10-10-15, 04:11 PM
  #40
sbcluser
sbcluser's Avatar
Interestingly, it appears that my 2015 IS350 F-Sport AWD is not like the example photos. Maybe it changed in 2015, or perhaps your is 2WD? For reference here are some photos.
Old 10-10-15, 05:24 PM
  #41
CBRNE
CBRNE's Avatar
Did anyone have 20" on their is, if so does it rub
Old 02-16-16, 08:06 AM
  #42
Kappy550
Kappy550's Avatar
Originally Posted by evident
not cool. can anyone else chime in with their experiences with ramps or jack stands? are there better jack stand resting points?
I've put my car on rhino ramps multiple times and changed the oil without a single hitch. Its an extremely simple task and takes me less than 30 minutes all said and done. I use Castrol Edge 0W-20 and a filter from the Toyota house. Costs me roughly 50 bucks total. They also carry the oil filter wrench at the auto parts store for < $5
Old 02-17-16, 03:49 PM
  #43
manchild
manchild's Avatar
Wouldn't a 1/2" drive extension work just as well as a F type socket? Looks like that square hole in the filter housing takes one.
Old 02-17-16, 05:23 PM
  #44
hotsaw11
hotsaw11's Avatar
I think a 3/8 drive fits.
Old 02-28-16, 09:52 AM
  #45
bv1773
bv1773's Avatar
Default the drain plug
hi all, I am new to this forum
For the next (first for me) oil change on my '14 is250, I want to replace the drain plug with one that has a magnet in it to gather fine magnetic particles.
Question one is does the Lexus drain plug already have a magnet?
Question two is what is the thread size?
Thanks
Quick Reply: DIY: Oil Change 2014+ IS350 w/ pics
