Rotor And Pads Change Help!!
Im going to change my brake pads to Akebono ProAct Ceramic Brake Pads
Front Manufacturer Number: ACT1118
Rear Manufacturer Number: ACT1391
I know there is no problem with changing just the pads from OEM to ceramic. but can i change the rotors as well without changing the whole kit? i don't believe thats a problem right?
Im going for StopTech Driller Rotors
128.44138L 128.44137R Front
128.44141L 128.44141R Rear
So Can i change both the rotor and the pads(knowing that they are from different Manufacturers)
without Changing the Whole Brake Kit?
Thanks.
Thanks.
Thanks.
Thanks.
Btw, does it affect the warranty or you do not take the car to Al Futtaim?
brakes aren't much to worry about when it comes to warranty. that's one of those systems that doesn't cost too much out of pocket to fix. but going to an after market part (not Toyota/lexus) will void any warranty on any part of the car.
i already ordered the pads, just not the rotors yet.
love the Stoptech drilled & slotted rotors with posi quiet ceramic pads !!
no dust - no noise - last long than oem pads
and dont worry about the warranty my car full bolts on and i do all my service at the dealer
i drove my car about 60K right now
my car set up :
- AFE magnum force cold air intake dry filter
- PPE ceramic headers long tube
- invidia mid-pipe
- Tom's axle back
- Tom's rear diffuser
- Stoptech drilled & slotted rotors with Posi quiet ceramic pads
- DVD bypass
- LED reverse bulb
- etc ..
my car set up :
- invidia mid-pipe
- Tom's axle back
- DVD bypass
- LED reverse bulb
- etc ..
