broke my wheel lock
07-29-15, 04:23 PM
broke my wheel lock
07-29-15, 04:28 PM
Former Sponsor
Ouch...as you can see the head of the stud that it was way over torque
07-29-15, 04:42 PM
Woah, yeah you could fix that with a lugnut remover and a hammer, so it shouldn't be too bad, or just take it to a wheel/tire shop down the street.
You'd need a new locknut now though
07-29-15, 04:45 PM
I believe I saw several youtube DIY videos on this subject.
07-29-15, 05:14 PM
How many ft lbs was the Tq wrench set too ??
~ Joe Z
07-30-15, 02:40 AM
Quote:
Originally Posted by
Joe Z
~ Joe Z
It was set to 40ft lbs. I like to torque from 40 then 80ft lbs.
07-30-15, 05:48 AM
Hammer a socket over it and loosen it with a socket wrench.
07-30-15, 10:23 AM
If it's not torqued on there with hulk strength, you should be able to DIY it by hammering a socket that's once size down over it to turn it out.
07-30-15, 01:06 PM
80 lb.. not sure how torquing mechanic works but its not that far off from factory recommended 76 lb.. anyone have any explanation?
07-30-15, 03:06 PM
toeknee88
Amazing to see this snap with only 40 ft lbs set on the Tq wrench..
~ Joe Z
07-30-15, 03:23 PM
If you don't have a high quality socket, go buy one. A cheap one may split when you tap/pound it onto the lug nut.
07-30-15, 03:47 PM
A tireshop like firestone can get it off in 10 minutes. They did that for my wife's jeep without damaging the wheel
07-30-15, 04:37 PM
toeknee88
What brand of lock? Lexus OEM? Under warranty? If yes, the dealer should be doing all this at no charge and replacing your lock set.
07-31-15, 10:36 AM
swfla
Yes, the OEM Lexus set. I'll give it a try and see if lexus will cover it.
GOOD NEWS! I was able to remove it with ease. My bolt remover tool was actually a bit too small so I smashed a 20mm socket over the nut and it came right out
07-31-15, 01:39 PM
toeknee88
Awesome, glad you were able to get the nut removed.
And now you know how to steal wheels like a pro too hahaha
Kvs_350
02-25-14 04:16 PM
Coconut
03-31-09 04:36 PM
HarrierAWD
RX - 1st Gen (1999-2003)
22
01-28-09 06:16 AM
tfz_hebe89
10-12-08 07:02 PM
yellowssm
06-27-06 04:51 PM
