Tried and true! Frs torsen diff on 14-15 is250
#31
so i ran the set up with and without the frs torsen LSD, man do i miss it and how strong it holds the ground around the loop. the problem i feel is that the rpms sit a bit high driving regularly. so i will locate a 06-XX is250 Manual trans, which have same final drive gearing. I will attempt to install the is250 final drive ring and pinion gear on the frs diff and reinstall it back on.
#32
update on the torsen t2 limted slip on the gse3. drives completely like stock. no changes whatsoever. what i did was picked up a m85 is300 manual trans pumpkin, i cleaned it up and slap new seals on it. also a direct fit and works as it was intended. power transfer to the wheels move side to side to the wheel with the best grip. recap. i ditched the frs 4:1 ratio final drive for a m85 3:7 final drive. is it that big of a deal? maybe. but it helps.
Ptrikz (05-22-17)
#33
That's why Lexus IS 250/350 don't have LSD Lexus Engineers thought of that ! i've been driven like an a-s-s lately these days to test out New Lexus IS350 suspension and AVS, had the car for awhile now in my opinion i would say Handling and grip is better than BMW 330ix i compared 2015 IS350 Fsport to a 2017 BMW 330ix, i thought 330ix suspension/handling were GOD, Fking same sh't, compare strut vs strut. Guess what i Spun out on track with 330ix. except the Suspension and steering wheel were little stiffer than Lexus in normal Mode but when i turn on SPORT+ on Lexus IS, i like it better the stiffness is just enough like me *****.
Lexus BMW Merc and Audi are Luxury performance, it's not worth to replace the parts with Aftermarket one, you guys are in delusion and imagination. oh i heard its good, oh i think or i feel my handling has improved, save money for Custom Turbo !
#34
A performance-centric component like a LSD that can help apply power to the ground under inclement weather or enthusiast-driving conditions is a welcome addition, regardless if you're driving a RC-F, IS250/IS350 F-Sport, 1st Gen IS300, or a FRS/BRZ.
#35
Do you always sputter nonsense when you type? ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
#36
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
Show me where I state that I have a 204hp car.
Reading comprehension is a fundamental skill that's obviously not for everyone...
jkonquer (05-25-17)
#37
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Guys take the rude personal comments to pm and out of this thread.
#42
Hi! New user here and I’m planning on doing this same swap on my 250. I had one question before I started mines , when you removed the axel from the diff did you HAVE to loosen it from the hubs ? Or would it just drop out ? And also any advice on how to loosen the axel from the hub if needed ? Sorry I know this is random but this was the only good info I found on this swap and I was hoping you might be able to help haha
Austin32
07-04-18 09:11 AM
