Most aggressive wheel setup?
What is the most aggressive wheel setup for the is? Think I'm able to run 20x9 +32 and 20x10.5 +38?
I'm thinking I'd be able to run it with a camber kit. Fronts should be fine, it's the rears I'm worried about.
If not what would you guys recommend for an aggressive wheel setup?
Im running 19x11+47 rears and im fine without camber sitting lip to fender, but im running camber regardless because thats the look i wanted to achieve. 19" and 20" are two different things tho.
Not much camber at all. Maybe -2 max. Definitely no where near the 2 digits. And no fender work done either. A little poke would be it too. I'm just wanting to fit these wheels on my car, without having a crazy stance
