Different tire size on IS350 F
Just curious why the 2014 IS350 F has two different tire sizes in the front vs. back even when the rims are the same size (18 inch)? It's kinda of a hassle becuase I can't rotate them and the front wear out faster.
Do you guys know if you can put the rear size tires (255/35-18) on all four? Thanks in advance!
Sorry for the lack of clarity guys...my IS is AWD. I know the RWD always have wider tires in the back but on my older 06 IS AWD it is also same tire size and rims all around.
I need to replace the tires soon and wanted to just get 4 of the same size since the rims are 18'' all around anyway...what do you guys think?
Front OEM wheels are 18x8", rear wheels are 18x8.5". If you want to run a square setup, I'd recommend 225/40/18 or 234/40/18 all around. Both sizes are more common/cheaper than 255/35/18 and will fit both front and rear wheels. 235/40/18 provides a bit more coverage on the rear but the speedo will be slightly off.
for directional tires, if you really want to do side to side rotation, you will need to flip and remount the tires inside-out so it can be used on the other side if you see uneven tire wear as a result of camber. This process is mostly not recommended.
normally you won't want to rotate side to side unless you have non-directional tires.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
