Widest tires on OEM Fsport rims
Hey all, looking to do the same to my '16 IS200t F Sport...has anyone here finally done the following on stock F Sport rims:
235/40-18 Front
265/35-18 Rear
If so, have you had any issues? Do you have pictures of how it looks, have you noticed any benefits/drawbacks?
Also looking at some Firestone Indy 500 tires, has anyone here tried those out? Hearing positive things about them, and they seem like a good bang for the buck for a summer tire (perfect for south Florida)
Thanks in advance!!!!
235/40-18 Front
265/35-18 Rear
265/35R18 is closer to 235/40R18 than 275/35R18.
See below link
http://www.1010tires.com/Tools/Tire-...5R18/275-35R18
See below link
Anyone have wider tires on OEM F sport wheels on RSR superdowns? Im thinking of going 265/35/18 Rear and 235/40/18 Front, anyone done this on RSR superdowns?
I'm running 245/40-18 on 8.5 +35 wheels, lowered on RSR Downs and only had a slight rubbing at full lock on the inner wheel well in the front. Depending on the wheels, 235 will fit fine in the front.
You don't want wide rear tires. These cars tend to understeer and that's the last thing you want to do. A square setup is the most optimal way to improve handling. However on a staggered setup, you would want to go as wide as possible on the front.
235 on front should be good and 245 would be better but it might rub. 255 on the rear is perfect for 8.5 in wheel.
