need help removed of tail light
hey guy need help removing my stock tail light, took out clip but cant pull off stock tail light no bolt on the back? please help
Inner or outer? The half on the trunk or on the quarter panel?
The inner have 4 10mm bolts then a very light prying should pop the foam seal away from the body.
I haven't removed the outer but I would imagine there are a couple bolts or screws under the caps on the inside part where it's black. I think the rest holds in with plastic guides.
When you open your trunk you will see two plastic tabs towards the inner most part of the tail light housing. You need to pop them off to expose two screws. Don't remember what size the screws are. After those are out you basically need to pull or shimmy the housing straight out. Be careful though because what's holding the housing in place are plastic tabs and there is also the wiring. Hope that helps
Patrickleo
11-01-17 07:36 PM
