What is everyone using for non-dealership oil?
I have a couple questions regarding the oil/oil changes,
1) Most people put around 6-6.5 quarts I'm assuming, is the normal amount cause most places sell it by the quart or 5 quart.
2) I wanted to double check, is the oil for 2015 IS250 f sport 0w-20?
3) Does it matter which Mobil 1 it is? (full synthetic extend performance or advanced fuel)?
Thanks everyone.
Thanks everyone.
Comparing specs
Toyota 0w20:
Relative Density (at 15 C): 0.851
Flash Point [Method]: 219C (426F) [ASTM D-92]
Flammable Limits (Approximate volume % in air): LEL: 0.9 UEL: 7.0
Autoignition Temperature: N/D
Boiling Point / Range: > 316C (600F)
Vapor Density (Air = 1): > 2 at 101 kPa
Vapor Pressure: < 0.013 kPa (0.1 mm Hg) at 20 C
Evaporation Rate (n-butyl acetate = 1): N/D
pH: N/A
Log Pow (n-Octanol/Water Partition Coefficient): > 3.5
Solubility in Water: Negligible
Viscosity: 36.1 cSt (36.1 mm2/sec) at 40 C | 8.5 cSt (8.5 mm2/sec) at 100C
Oxidizing Properties: See Hazards Identification Section.
Freezing Point: N/D
Melting Point: N/A
Pour Point: -27°C (-17°F)
DMSO Extract (mineral oil only), IP-346: < 3 %wt
Mobil 1 Extended Performance
SAE Grade 0W-20
Viscosity @ 100ºC, cSt (ASTM D445) 8.6
Viscosity, @ 40ºC, cSt (ASTM D445) 44.9
Viscosity Index 173
Sulfated Ash, wt% (ASTM D874) 0.8
HTHS Viscosity, mPa•s @ 150ºC (ASTM D4683) 2.7
Pour Point, ºC (ASTM D97) -54
Flash Point, ºC (ASTM D92) 235
Density @ 15.6ºC g/ml (ASTM D4052) 0.839
Mobil 1 Advanced Fuel Economy
SAE Grade 0W-20
Viscosity, @ 100ºC, cSt (ASTM D445) 8.7
Viscosity, @ 40ºC, cSt (ASTM D445) 44.8
Viscosity Index 173
Phosphorous (ASTM D4951) 0.065
Flash Point, ºC (ASTM D92) 224
Total Base Number (ASTM D2896) 8.8
MRV @ -40ºC (ASTM D4684) 9200
Density @15.6ºC g/ml (ASTM D4052) 0.841
pH: N/A
Freezing Point: N/D
Melting Point: N/A
SAE Grade 0W-20
Viscosity Index 173
SAE Grade 0W-20
Viscosity Index 173
sweetboy02
RX - 3rd Gen (2010-2015)
22
06-23-14 09:35 PM
