2015 IS250 F/Sport Tire Pressure
Hello everyone...
Wife just picked up a 2015 IS250 F/Sport and had a question on tire pressure...Seems the dealer has the rears at 41 and the fronts 38....Is that what is recommended as far as performance tire
brand ?...The door sill says otherwise ..so my question to you all is..keep as is or go by the door sill standards?
Tires are Bridgestone Turanza ER33...the OEM tires
Thanks all
Thanks all
It's 36 PSI cold. If you are driving, they tend to be 2-5 PSI higher. Do the measurement when you first drive the car to determine if the tires are at the right PSI.
Originally Posted by lpandroc
EZZ..these are cold numbers
When I had my two services at the dealer, the tire pressures were higher than the 36 listed on the door. I have no idea why they do that.
I just adjusted the pressure after the tires cooled.
