Regular Gas
Old 10-25-15, 11:18 AM
goldengame
goldengame's Avatar
Default Regular Gas
Hey guys,
I'm an idiot. I accidentally put 15L (~4 gallons) of 87 in my IS350 before I realized what I'd done. Then I filled the remaining 26L (~6.9 gallons) with 91 (this Shell had nothing higher than 91). I added half of a small bottle of STP octane boost (the whole bottle is supposed to be good for 80L of gas). Do you guys think my car will be okay? Is there anything else I should do to mitigate any damage it might cause? I guess my biggest fear is getting engine knock.
Thanks guys
Old 10-25-15, 11:25 AM
TGIF
TGIF's Avatar
You will be fine. You can use regular if you wanted to, and the engine would "de-tune" itself. You will not do any harm to your engine at all. Now if you had put in diesel, that would be another issue!!
Old 10-25-15, 02:42 PM
KYLESTONES
KYLESTONES's Avatar
Did the same thing Friday!
Old 10-25-15, 03:03 PM
dchar
dchar's Avatar
You would've been fine even if you put a full tank of regular without octane boost. Car will adjust itself and you would get less performance.
I know some people with BMWs (even Maserati) that put regular gas in their cars on a regular basis because they are too cheap to pay for premium. Their cars run fine without CEL.
Old 10-25-15, 03:19 PM
evident
evident's Avatar
you'll be fine, i had a brain fart and filled my entire tank before with 87.
Old 10-26-15, 06:32 AM
4TehNguyen
4TehNguyen's Avatar
eh just burn through it, it will run crappy for a bit but no damage
Old 10-26-15, 06:48 AM
andysvette
andysvette's Avatar
For those of you that run 87 on a regular basis, do you notice a big difference in performance?
Old 10-26-15, 12:05 PM
Silver250F
Silver250F's Avatar
I run 87 in my 250 tbh. It runs fine with no weird sounds or mpg drop. Not sure about performance because it's slow af anyways aha. I wouldin't run 87 on the 350 or the 200t though. It's weird how the RX350 calls for regular 87 though
Old 10-26-15, 02:12 PM
4TehNguyen
4TehNguyen's Avatar
RX350 is just a camry engine like the ES350, and regular is fine in the camry
Old 10-27-15, 12:59 PM
goldengame
goldengame's Avatar
In the morning when it was a little chilly (around 6ºC/43ºF), it did have a little vibration when idling that it didn't have before. Also it feels a bit sluggish, but that could just be in my head.
Old 10-28-15, 01:27 PM
BostonIS
BostonIS's Avatar
So I got into a debate with my friends about putting premium in my IS350 and they said its all a gimmick by the car manufacturers to say that it needs premium gas. I looked it up and it says there are cars out there such as the IS350 that require premium versus "recommended." While I firmly believe that if a car needs premium then put premium but other than possibly damaging the engine to a car, are there any other reasons that you should put premium?
Old 10-28-15, 02:52 PM
dchar
dchar's Avatar
Modern engines all can adjust between regular and premium without any problems or damages. You'll get less performance and fuel economy may suffer a bit when using regular instead of premium in a car that says premium is required.
Old 10-28-15, 04:56 PM
MWIS350
MWIS350's Avatar
You should be ok but just don't do it again and again
IS350SWFL
IS350SWFL's Avatar
I use regular gas in my car and there hasn't been any difference in fuel economy or performance from when i put premium gas in it.
Old 10-28-15, 04:57 PM
MWIS350
MWIS350's Avatar
I used 87 in my car before but it run like crap and get bad gas mileage. Now I only used 92-93.
Quick Reply: Regular Gas
