275/30-19 19x9.5 +40mm offset on stock suspension?
Old 11-10-15, 05:39 PM
plastus
plastus's Avatar
Default 275/30-19 19x9.5 +40mm offset on stock suspension?
I've searched through the forum threads but wasn't able to see anyone that has stock suspension that is running 19x9.5 +40mm offset in the rear with 275/30-19 tires. Anyone know if this will fit or will I get rubbing under normal driving/passengers in back seat?
Old 11-10-15, 07:48 PM
lildjloop
lildjloop's Avatar
I'm running 265/35 on the rear with 19x9.5 +38 with a drop and have rubbed once with two passengers. Don't think u will have a problem with rubbing.
Old 11-10-15, 09:18 PM
ATP
ATP's Avatar
if your not dropping your car it shouldnt rub.
Old 11-11-15, 06:19 AM
plastus
plastus's Avatar
Thanks guys. I'm close to puling the trigger on a set of Avant Garde M580 wheels which are 19x8.5 +35mm and 19x9.5 +40mm with 235/35-19 and 275/30-19 tires because it gives me a perfect 25.5" rolling diameter.
I could go 225/35-19 and 265/30-19 which is closer to the stock 25/25.1" diameter but I'm afraid that the 225 width tire will be stretched on the front 8.5" wheel.
hunodos
05-08-19 10:15 PM
Jaypmanuel
02-03-19 07:03 PM
Focal
06-09-18 09:08 AM
mikelexF
IS F (2008-2014)
09-13-12 10:33 PM
TinCan
IS F (2008-2014)
50
06-05-11 11:31 AM
Quick Reply: 275/30-19 19x9.5 +40mm offset on stock suspension?
