Rear clunking noise..
Hello all,
I tried doing a search for my issue and couldn't really find anything except for people hearing clunks while going over bumps.
My situation in particular is when I park my car after a drive (duration of drive is irrelevant as this has happened during different driving times) on a slight incline with the e-brake about 80% depressed, I hear an audible clunk from the rear driver side area when I leave the car (weight shift when I step out). The clunk sounds like two pieces of metal slapping together.
Has anyone experienced this at all?
Hello all,
I hear what I can best describe as two metal plates hitting each other but I hear it when I go over small bumps or uneven surfaces at very low speeds. When I took it to the dealer they said it was a loose parking break component. They said they tightened the parking brake parts and said it was fixed. However, when I got the car back I still hear it. Have you taken your car to the dealer?
Is your parking brake properly? I meant when your car is in neutral and you are on a slight slope (say on a typical driveway), and you press your parking brake fully, does your car move? (i.e., the parking brake won't hold the car by itself)
Thanks.
Yeah, it could just be the parking pawl, or the metal noise could just be the weight of the car straining against the e-brake parts that are holding the car's weight. And don't forget, our cars are portly beasts for a compact!
Do we have the brake shoe-design parking brake in the back?
Received 1,737 Likes
If you're hearing it from the rear is could just be the parking brake shoes settling after the weight shift from you getting out.
You could either try depressing it more so it is definitely firmly applied, or make sure it is adjusted properly.
With proper adjustment the parking brake should hold the vehicle on a slight incline/decline...if you really think about what the parking brake is for, if it can't hold the vehicle stationary on flat ground or slight incline/decline, then you have no chance in ever stopping the car should the hydraulic brakes fail.
Personally I've never had a Toyota/Lexus/Scion from the factory that had the parking brake adjusted tight enough for my liking.
