AirForce Air Suspension
Old 01-10-16, 02:32 PM
sgvlex
sgvlex's Avatar
Default AirForce Air Suspension
Anyone rolling in Air Force Air Struts on their 3rd Gen IS RWD? Need some help with a few issues with the rear tapered bags. Thanks in advanced
Old 01-10-16, 07:50 PM
iSuxeL
iSuxeL's Avatar
I'm not but I've bagged a 3IS before, what's up?
Old 01-27-16, 08:58 AM
sgvlex
sgvlex's Avatar
well, I was told i had to run 150+ psi in order to get the rears to lift, I didn't feel comfortable with that so i swapped them out for UAS bags
Old 01-27-16, 02:27 PM
Silec
Silec's Avatar
Are you using airhouse 1? If so be careful of the rubbing between the bag and sway bar linkage.
Old 01-27-16, 02:30 PM
Silec
Silec's Avatar
Also that type of psi is pretty normal for sleeve bags due to their slim profile.
Old 01-27-16, 04:00 PM
sgvlex
sgvlex's Avatar
well my installer was trippin out about how high that psi is and how dangerous it is and since i dont know much i followed his recommendation. the UAS bags have a custom bracket that push it away from the arm so there isnt any rubbing that i can see
Old 01-27-16, 05:55 PM
xxwhosnxt
xxwhosnxt's Avatar
yea those aren't so good,
I'm getting my car bagged this week I'm going with bc coils over uas bags
Old 01-28-16, 12:59 AM
Silec
Silec's Avatar
You do realized most of sleeve bags are rated at least 200 psi?if not more. They are good in tight space but need most pressure to inflate since they are smaller. I had rubbing issues with the airhouse 1 in my rear that's why I brought it up.
Old 01-28-16, 10:51 AM
jkhang714
jkhang714's Avatar
Im on bags and i can tell u it doesnt take 150psi for rears to lift. It does take around 110-130 depending how high u want it to raise, but its completely safe.
Old 01-28-16, 02:34 PM
sgvlex
sgvlex's Avatar
i took a drive on it I had like 120 psi on the rears, and it was really low and unstable, after i got the uas bags installed the ride felt solid :-/
Lammyyy
RC F (2015-present)
05-18-18 08:56 PM
Lveyolfe
06-12-17 11:20 PM
JediKeith
CT 200h Model (2011-2017)
03-20-13 01:29 PM
SCSUPERSTR
04-20-11 10:06 PM
celsiorlee
18
12-14-08 11:09 AM
Quick Reply: AirForce Air Suspension
