2014 IS350F-Sport: What are the Wheel Specs?
Old 01-15-16, 10:35 AM
ba2sy
ba2sy's Avatar
Smile 2014 IS350F-Sport: What are the Wheel Specs?
Hi! What are the wheel specs of 2014 IS350F-Sport? Wheel size, Offset, and Bolt Pattern?
I'm curious because I have staggered wheels for a new friend:
Avant Garde M621
19x8.5, Offset +43, Bolt Pattern 5x114.3, Acorn Lugs 12x1.5mm
19x9.5, Offset +34, Bolt Pattern 5x114.3, Acorn Lugs 12x1.5mm
Do you guys think it will fit? Any rubbing with stock setup?
Old 01-15-16, 11:36 AM
anthonys2r
anthonys2r's Avatar
those will work with no rubbing
Old 01-15-16, 11:39 AM
ba2sy
ba2sy's Avatar
Thanks! Do you know the stock wheel specs though? I'm guessing you guys have the 18" size and Bolt Pattern 5x114.3 but how about offset?
Old 01-15-16, 02:45 PM
Answer
Answer's Avatar
5x114.3 is correct.
60.1mm hub bore
Front: 18x8 +45
Rear: 18x8.5 +50
Old 01-15-16, 09:21 PM
ba2sy
ba2sy's Avatar
Originally Posted by Answer
5x114.3 is correct.
60.1mm hub bore
Front: 18x8 +45
Rear: 18x8.5 +50
Thanks! For the details... Same hub bore as RCF then... But different offsets...
Old 01-19-16, 05:19 PM
ba2sy
ba2sy's Avatar
What's a good tire for the rims mounted on a 2015 IS350 F-Sport? The 275/35ZR-19 Continental ExtremeContact DWS 06? It started rubbing on the rears with 2 wheels in the backseat and 2 wheels in the trunk.
marlu
RC F (2015-present)
08-16-14 08:08 PM
wmb0000
03-19-10 10:28 AM
DallasLex
02-10-08 07:26 PM
CSHFLW
08-17-01 01:19 PM
Quick Reply: 2014 IS350F-Sport: What are the Wheel Specs?
