20s on 2015 is250 F sport?
I found a set of 20s for a fairly good deal, they are 5x114 lug pattern, 20x8.5 front, and 20x9 in the rear.. The tire size on them is 225/35/20 front, and 275/30/20 in the rear. My question is will these fit with no rubbing issues or anything long those lines. The car is a 2015 is250 F sport. Thanks in advance any help is appreciated
Ive got a 235/35/20 front with rsr half down springs. the drop is mild. the tires rub when the car is at an angel and i turn the wheel to the max. its not an issue. the rear ones are fine. they wont rub and dont use spacers on 20s if youre lowering it.
I got 20s lowered on rsr down springs and i rubbed like crazy. I had to roll all fenders and get rear camber kits. I still rub messing up the rim. I did get a jlw7 13 inch which ways a grip so im sure that contributed
honestly, i'd say you're perfectly fine. steveo55 and I rub because we're on 20x9F and 20x10.5R but since the wheels you're looking at are 20x9 in the rear.. you're fine, brother. don't think you'd need a fender roll or anything. tire rub is what I'd think of at most, but the rim itself? you're good.
so a 5mm spacer wont be good in the front? if i dont run the spacer the wheel wont fit... why is the spacer bad?
PNice972
05-22-07 09:03 PM
