Swapping from RSR downs to half downs
Im running 20s have spc rear camber arms and still rub like crazy in front and rear. Im thinking of switching to half downs. Still want to be slighlty lower but bot have to worry about rubbing. I also kinda rub when i go over a speed bump towards the middle of the car. It all got worse after i got a W7 subwoofer. What are your thoughts.
its not your springs, its your wheels. you have to get the right specs...offset and such. i ran 19x10.5 +45(REAR) 19x9.5+40(FRNT) on RSR downs with no issues. but i switched to half downs, cuz the downs were a little rough for my liking.
all depends where you're rubbing. If you're rubbing due to low offset issues, then it's an offset issue (duh). If you're rubbing the inner fender well due to having large diameter wheels, soft springs and extra weight in the car, then yes, I would assume a less aggressive drop would help.
Im running vossen vle1s i think the specs are 20x9 +32 w/ 225/30/20
20x10.5 +45 w/ 245/30/20 it was rubbing like crazy before the rear camber arms less now. I have fenders rolled front and rear. Fronts i kinda damaged left front fender paint cracked and peeling from rubbing i touched up looks better on back you cant even stick your finger by where the back bumper and fender meet i think thats whats damaged the rear rims it has to be rubbing hard there.
Crazy part i called vossen before i got them and the gentleman who answered said he had same car same wheels same specifications with no rubbing. He told me what size tires to buy. I thought i was golden. Well now i have the wheels have to figure out what to do.
what tire size did you run ? any pics with super downs ?
bottom line:
you can be slammed to the ground and not rub. the issues at hand are:
1. aggressive wheel specs
2. your current camber setting is not allowing tire to clear fender. you need MORE negative camber to have the wheels clear. this will affect your tire life.
3. mods are going to take a little more than just set it and forget it
