Ark exhaust install question
Hey guys,
So went to get my Ark Grip exhaust installed today. The shop cut my stock exhaust because they couldn't slide it out with the brace being under the exhaust. Is that normal or should they have been able to take off the brace and pull out the exhaust? Attached a picture of the brace on another car but same idea. Will I be able to go to another exhaust shop and have them weld it together if I want to go back to stock?
Sorry for the lack of pictures.
They were suppose to remove that brace. Thats for almost every car, you simply unbolt one side, move it, and slide the exhaust out..
-Josh
-Josh
__________________
![](https://www.clublexus.com/forums/signaturepics/sigpic167102_16.gif)
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Thanks guys. Looks like I chose the wrong shop... Definitely gonna have another shop check out my exhaust to see if it's even installed correctly
I got my old exhaust back after installinh my ARK system in one piece. Thats the brace i keep telling everyone my ARK would hit and cause the rattle. They installed washers i saw the mechanic take the bolts off he didnt struggle at all looked simple. Now your kinda screwed if you want to go back to stock
Yeah my husband and I installed mine ourselves and we just removed that brace, removed the stock exhaust, installed the new exhaust and replaced the brace. They definitely shouldn't have cut anything.
-Josh
__________________
Orange County, CA
Orange County, CA
True, it is annoying but thanks for the replies guys. Just got unlucky with the shop but good to hear I can go back to stock if need be.
Hello I just installed this ark exhaust on my car.
I have question for you.
1. the part of the H pipe is rest on the brace.
1.1- is this normal?
1.2- do you need this brace?
2. where did you get that brace to replace the OEM one?
3. does your make that annoying too loud sound (or drone) at around 1500-2000 rpm?
4. my car make louder exhaust sound from the truck (rear) than it make from outside the car is this normal?
5. did you sound deadening your car?
Chedeng88
Chicago Lexus Club
11-28-18 05:54 PM
