RS-R Super Down Lowering Springs - INSTALLED
I agree, also unless you get aftermarket shocks that are meant to work with lowered cars, then using stock shocks with such an aggressive drop will likely make them fail very quickly. part of the reason I went with half-downs.
Let me know if you want to go with some down's instead. You might start scraping everywhere. :P
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Strange, I've seen some members on here with Super Downs and they don't look as low as yours. I'm going to assume it may be from the angle of your photo, you don't have any spacers on and you didn't do an alignment yet. I mention the alignment because you're possible having some camber and after the alignment it'll fix the camber and raise it a tad bit. I would suggest getting some spacers like other members on this forum do. But I too bought the Super Downs and 20mm spacers all around and I have yet to install them. Refer to RayG's photo, his looks pretty good with the Super Downs. I don't know if I should be worried about installing them now after seeing your post...
Refer to this thread. IMO, the drop looks perfect on posters car.
https://www.clublexus.com/forums/sus...your-pics.html
Another thread you can refer to. After browsing through it, I really suggest getting some spacers so you don't have that "tuck look". Instead you'll have that flush look.
https://www.clublexus.com/forums/sus...er-down-7.html
super downs looks good when first installed but give it a few months to a yr and it will settle much lower....also it will wear out your stock stocks faster and you'll be hitting the bump stop more often than not given the little suspension travel left after the drop....imo downs are the perfect balance ....just my 2 cents
-Josh
__________________
Orange County, CA
Orange County, CA
