Cracked F Sport Grille
I have a cracked F Sport grille.
Anyone know where I can obtain replacement at the lowest possible cost?
Also, how difficult is it to replace the grille; something I can do myself?
Thanks!
Thanks!
is it the upper or lower grille? they go for ~$200 each. edit: i found a few on ebay
Upper $221
Lower $152
installation is done from the back, so you gotta remove the bumper, which is pretty easy, a few tabs. only caveat is that you have to be REALLY genital when removing said tabs. they are thin and fragile., but if you take your time, you'll be fine. once the bumper is off, locate snap tabs around grille and depress and remove. again be careful and take your time
Upper $221
Lower $152
Thanks for your prompt reply!
From what I can tell it looks like there's only one grille! Do they interlock somehow?
That said, it looks like I wasn't as clear as I should've been...
The grille itself isn't cracked, but the chrome trim around it, which definitely seems like one piece.
Is the chrome trim around the grille a separate piece in and of itself?
Thanks again!
Thanks again!
Hmm; looks like it's a separate piece as well!
http://www.ebay.com/itm/14-15-OEM-NE...tWChym&vxp=mtr
for installation, the tabs removed from the back, and the trim will pop out from the front
yes no way possible to remove the Grill with bumper still on the vehicle.
There are at least 4-6 Phillip screws you have to remove besides releasing the retaining clips before the grill is separated from the bumper.
