Gas for 200t, does it really need premium?
Old 04-15-16 | 01:07 PM
  #31
nathantse's Avatar
nathantse
Originally Posted by mjeds
the government sets fairly stringent standards for all gasoline that is sold in the United States. When it comes to octane level and other specific gasoline characteristics, all gas is basically the same. The difference between the fuel that you buy at branded gas stations comes down to the detergents that are added to the gas.
The federal government has required since 1995 that all gasoline which is sold in the US must contain a certain amount of detergent additives. These additives are Environmental Protection Agency (EPA) approved, and the government has specified the amount of detergent which must be added to keep vehicle engines free from deposits. Costco gasoline meets all these requirements, or it couldn’t be sold in the United States.
A number of automakers made the decision that the US government additive requirement wasn’t high enough for many cars. As a result, they developed a “Top Tier” standard. In order to meet the “Top Tier” designation, the fuel sold at the gas station had to meet additive requirements higher than is required by the US government. Costco fuel meets this top-tier standard. Costco gasoline is rated as equal to any other major brand gasoline
Soo..that is a yes? I'm planning to open the new Citi Costco card, and that 4% cash back sounds sweet for gas.
Old 04-15-16 | 01:37 PM
  #32
mjeds's Avatar
mjeds
yes.............
Old 04-15-16 | 01:40 PM
  #33
listairee's Avatar
listairee
Yes. Costco is a top-tier licensed company. Here's the link to see who has the top tier licensed.
Old 04-15-16 | 01:43 PM
  #34
listairee's Avatar
listairee
Originally Posted by corradoMR2
It's close to Canada's cost. We pay about $0.20 /L more or about $0.75 more a gallon for premium fuel. At that price difference, it's easier to see why people ask the questions on the effects of using a lower octane fuel. But rule of thumb, if it says "PREMIUM FUEL REQUIRED", put that in. If it's "recommended", save the money and go with 87.
Oh, I'm just stating the difference. I've always been putting premium gas in all my cars and bikes, even in my first car, which is a Corolla.
Most of the 91 here have ethanol in them so I have to make sure that the gas station that I go to does not have that added into their gas.
Old 04-15-16 | 02:51 PM
  #35
Lex2133's Avatar
Lex2133
Just so you know, if you currently have a Costco Amex card, you don't have to 'open' a Citi Costco Visa card. It will automatically arrive in the mail early May-2016. And by the way, they won't even run a credit check on your file.. It will simply replace your Amex.
And if you've not had a Costco Amex, you missed out on a ton of cash back...
Cheers
Old 04-15-16 | 03:26 PM
  #36
mcomer's Avatar
mcomer
Additional factor at play here. When using an octane lower than designed for
the motor generally retards the spark advance to minimize pre-ignition "Ping".
This affects both throttle response and MPG's. When justifying the economy
of using the 87 level fuel you must factor back in the xx% lower MPG.
Save 10-20% at the pump but get 5-15% fewer miles per gallon?
Old 04-15-16 | 03:41 PM
  #37
Olasek's Avatar
Olasek
This nonsense has been disproved many times by empirical data - there is no measurable difference in MPG when using the lower octane (provided otherwise the fuel meets the minimum federal guidelines and 87 octane).
Old 04-15-16 | 05:32 PM
  #38
litesoarer's Avatar
litesoarer
What mpg you'd lose from timing being cut by the computer, you'd gain back in BTU's.
87 has more BTU than 91.
Old 04-15-16 | 06:06 PM
  #39
CarlitoIS's Avatar
CarlitoIS
If you love your car, don't go cheap. Lexus recommends premium, just go premium. I don't have an issue paying what 20 cents more a gallon?
Old 04-15-16 | 06:17 PM
  #40
litesoarer's Avatar
litesoarer
And neither do I.
But I DO have an issue with 40-70 cents more per gallon on a $2 base price.
Solution: Find name brand gas stations with cheap premium compared with average regular price.
Old 04-15-16 | 08:16 PM
  #41
gregerst's Avatar
gregerst
There's a difference between cars that recommend premium fuel and those that require it. Our cars need premium. It's in the owner's manual. Use high octane for high compression engines otherwise you risk hurting the engine. . Can you get away with running regular fuel. probably, but there could be that one day when your running crappy low grade tank of gas and when you push the engine hard the fuel in the cylinder prematurely ignites. Ouch!
Here's Edmunds lists of vehicles.
Required
http://static.ed.edmunds-media.com/u...red.031816.pdf
Recommended
http://static.ed.edmunds-media.com/u...ded.031816.pdf
Old 04-15-16 | 08:34 PM
  #42
litesoarer's Avatar
litesoarer
If overinflated premium is all that's available then i'll opt to do a half prem/half reg for ~90 octane and back off the throttle a touch. I absolutely will not pay over 50c (25%) above regular price.
The car I owned before my LS460 was a Sonata 2.0T.
While they claimed it'd do fine on regular (poor knock sensors!!), I knew better than that when the stock turbo was turning over one atmosphere of compression (17-18psi)
Old 04-16-16 | 06:34 AM
  #43
NateJG's Avatar
NateJG
Default B
Originally Posted by EJ255t
and here we go again!! most, if not all lexus will require premium gas!! All cars that have force induction require premium!!!
Not entirely true. Some of VWs Turbo 4s now prescribe Regular. We took Wifie's 2014 VW Beetle Turbo on yesterday's 300 mile trip (instead of taking my Premium fuel RX 450h).
The VW gets much better gas mileage than my Hybrid (apples to oranges, agreed) on the highway. We got 38 MPG yesterday from Kalamazoo to Wisconsin.
Old 04-16-16 | 07:40 AM
  #44
AMNss's Avatar
AMNss
My advise to you is to use the recommended by the manufacturer. Changing from one type to the other without checking the spark plugs comparability will heart your engine. Additionally if you over the recommended fuel you will be wasting money on gas and the power advirtsed was obtained using the recommended fuel, so getting higher octane fuel will increase the power, but it is not worth it since you will not feel it or use it 80% of the time. However going lower than the recommended fuel will decreease power and you could blow your engine.
Old 04-18-16 | 07:12 PM
  #45
My0gr81's Avatar
My0gr81
Note that AKI 87 fuel = RON 91 which is what the SAE filing for most of Lexus' engine are rated at. "Premium" fuel is marketing gobbledygook as every gas company has different definition of what that is. For the engineer in you, 87 AKI (using avg(RON+MON) method) intended fuel to use.
