I'm looking to do a setup on my is350. I've been looking at a few style rims but haven't decided. I heard that 19x10 km20 from Klutch was possible to do on all 4s. I'm not sure if it's true. Does anyone have any ideas on what's the largest and widest tires I can put without rubbing. I'm looking to do 19s. Def concave!
there's a lot of factors that go into this. with negative camber and fender mods, you'll be able to fit really wide wheels. depends on the look you're going for.
I'm trying not to do any mods to the car. I'm prob going to do 8.5 in front and 10.0 in rear. I think 225/35 fromt and 265/30 for rear
it depends on the wheel type, off set, lowered???...etc!! every wheel is different and the specs as well.
Not lowered, but the Klutch km20 doesn't say any offset. I would like to get those but not sure if 19x10 will fit all around. I'm new to the rim world.
you can do 19x9 19x10.5 with a 275/30/19 rear and 235/35/19 front
This picture was taken with 220-250lbs in the back and there was still plenty of clearance. No rub! Just as long you don't speed thru a speed bump like a maniac! I think with two people it should be fine and 3 is cutting it close.
[QUOTE=ABomb;9458531]
That looks really good! Thanks
Can anyone sit in backseat? Haha
