Seats Hurting my Back in IS 2014 Sport
Old 04-26-16, 01:37 PM
Jskrapper
Jskrapper's Avatar
Originally Posted by dnasians
try lowering the rear part of the seat all the way down
then raise the front part up to where it's comfortable
there should be a slight recline
and then adjust lumbar support
This is what I do. I am 6'3" and 200lbs. My back is in decent shape but sometimes I have a terrible time finding comfort on long rides in any car. I set it like a dentists chair if that makes sense. Thigh support high, butt support low, reclined a bit but closer to the steering wheel for arm comfort, yet far enough away for knee comfort. Its a fine line.
Also, driving with both hands on the wheel helps elevate my comfort levels.
Old 04-26-16, 02:39 PM
AdvanSLF
AdvanSLF's Avatar
Just to be clear, the seats are not giving you sciatica. The seats may not make you comfortable or promote your discomfort to make your sciatica more blantant. In any case, your sciatica won't go away unless you treat it, regardless of where you sit, stand, or lay. This is from my experience where my sciatica got so bad I had to take two straight months off of work. I could not walk, stand up or worst of all sit. Had two herniated discs pinching the nerves constantly. The only slight relief was laying on the lazy boy but the pain just comes back after a short while. I didn't want to do surgery, yet at least, so I tried the steroid needle procedure. Yes, it is what it sounds. They stick a needle about 7-9 inches long in your back filled with steroid meds to address the sciatic pain. Normally the procedure requires three shots on three different visits. Success rate is about 70%. After my second shot I felt amazing and didn't go back for a third. This was five years ago and I haven't had any problems since! Try it!!
Old 04-26-16, 07:07 PM
jat0223
jat0223's Avatar
Originally Posted by tas02
Welcome to the board, Blotterman.
Yes, you're in the wrong forum as stated by bnizzle87 & jspecvtec.
Your issue can also occur in our cars as well, especially in the '08 - '11 model year F.
What's different in the 12 and up MY seats?
Old 04-26-16, 07:27 PM
tas02
tas02's Avatar
Originally posted by jat0223:
"What's different in the 12 and up MY seats?"
They're in a vehicle with a slightly more compliant suspension.
Old 04-26-16, 07:38 PM
jat0223
jat0223's Avatar
So then you meant 08 to 10 MY.
Old 04-26-16, 08:01 PM
flowrider
flowrider's Avatar
Received 1,943 Likes on 1,369 Posts
Originally Posted by blotterman
I am confused, is this the wrong forum for this? Where should I post this question?
Yes, this is the ISF Forum, The IS F-Sport is NOT an ISF.
Here:
https://www.clublexus.com/forums/is-...4-present-249/
Lou
Old 04-27-16, 03:51 AM
dstopsie
dstopsie's Avatar
Here:
Lou
This is not an ISF forum. It says IS third-generation 2014 to present at the top so I don't understand where you're saying this is an ISF forum. The guy said he has a 2014 F sport he's in the right forum far as I can tell
Old 04-27-16, 06:22 AM
AdvanSLF
AdvanSLF's Avatar
Lololooolooololilookloolllll!!!!!!!
Old 04-27-16, 06:49 AM
xellos
xellos's Avatar
This thread was moved from the ISF forum to here.
Old 04-27-16, 09:01 AM
chris07is
chris07is's Avatar
this was moved to this section, because it was posted on the IS F forum. Most members, specially the newbies get confused between F sport and the real F.
john55657
09-01-17 12:53 PM
FUZCO
02-25-17 10:14 AM
SIRFLOW
10-03-16 05:56 PM
corradoMR2
NX - 1st Gen (2015-2021)
24
01-28-16 12:48 AM
yoegster
02-03-12 11:55 PM
Quick Reply: Seats Hurting my Back in IS 2014 Sport
