JDM fogs with seperate switch
Anybody use a separate switch to power the the fogs? I know the stalk method is better but 1100$ seems steep. If so, what kind of switch the looks of is oem? Thanks in advance
You're right, that is steep as &^!~@.
I had mine installed for 40$ . Harness is cheap, the time it takes to put on is so minimal you could sit in your car while they do it.
Don't fall for anything more than $100.
I have my fogs on a separate switch on the left of my dash (toggle switch, master)
Happy circuiting.
Happy circuiting.
https://www.clublexus.com/forums/gs-...s-vs-cree.html check this forum on how he did it he explains it pretty well
im in the same situation, I have the nigel switch for my fog lights but im not sure which wire to tap on?? I keep reading to tap on the ignition wire but im not sure which one is it
does anyone know?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
