F-Sport Fog lights
#31
can you tell if that plastic surrounding the foglight has the same texture as the OEM JDM ones? if not do you think the jdm cutouts will fit the light fixture? hopefully the plastic surrounds look good enough. they look good in the pics. as i said before, even if the light itself isn't that good, buying some components from retrofitsource may make it as good or exceed the oem ones
#32
I was just thinking maybe my car somehow did come prewired since there is so many loose conectors in that area where the fog lights go. Look at the pictures I put up before and see if any of those conectors would fit on the JDM fog lights. Thank you
#34
Night pictures
I guess in the end it all goes back to the old saying, you pay for what you get. the light output ain't that impressive. They are too dim for my preference. But they do match the color of the headlights by 95%. The pattern is scattered everywhere. Wish it was a bit cleaner but it ain't. Here are some pictures
#35
GR3Y5H3ART (03-02-20)
#40
Looks like these Spyder ones do not have shields to produce cutoff lines. The OEM has shield on top and bottom I believe when I took them apart to investigate
#43
[QUOTE=specONE;9466704]It's not there. If there were I would have done it that way. In my car when i installed OEM JDM fogs I just ran separate switch/relay harness
Wiring harness for direct plug in are there. I'll open another thread to show where I found it and how I did it.
Now I just have to figure out if I want to do a retrofit to HID projectors or save money to get JDM fog lights.
#44
[QUOTE=Edwin8484;9477428]
I thought about retrofit the fog light before I chose ijdm fog lights. I even bought 2.5" lens from theretrofitsource, jdm fogllight cover from nigel-jdm and 6k lmz led series from vleds. However, there were a lot of works and I did not have enough space for the led heat sinks and that's when I give up.
