200t Intake Tube
Lexus Enthusiasts
Can anyone clarify for me what the tube with the red arrow is doing? It looks to be routed to the top of the intake manifold ...
Attachment 385493
Attachment 385493
1- Unplug the hoses and check which one is covered in oil from the inside, this should be the breather tube. If both contain oil go to the next step.
2- If you can still not determine, plug the intake side with any cover which can be bought from any local store, and start the car. If you step on the gas pedal (on neutral) and take your foot off and you hear the BOV sound then this hose is for the air recirculation. This method have to be done on one hose at the time for determination.
Note: you can open those hoses to atmosphere with no issue to the car, but the intake side have to be closed. Please note these "hoses" should not be plugged at any time since this could damage your car's engine in a small period of time.
Thank you for taking the pictures, from the location the hose seems to be the air recirculation tube. Additionally the second line also seems to be connected to the same location, but I'm speculating that it is the breather tube (which you can connect an oil catch can to) since it is connected downstream far away from the MAF, and to the hotter metal part which helps keeping the vapor in its state due to heat and turbo suction . To determine the functions of these hoses do the following:
Maybe if the car had MAP instead of MAF
I'm looking into making my own intake system, that's why I'm inquiring about these hoses. Burger Tuning has a basic intake system and there are some aftermarket filters but none, that I've found, that are full blown intake systems.
Anyway Mike the most important parameters to consider for making your own intake system are:
1- Make sure the MAF is not affected in the new intake, position and orientation should be the same.
2- Increase the pipe diameter to give the turbo more air (I think 3.5 is good).
3- Use as less bends as possible, and use mandrel bends whenever there is a bend.
4- Fabricate inlets for the hoses as they will not decrease the performance.
