Plug&Play F-Sport Foglights/Auto Wipers (DIY)
Old 05-08-16, 10:40 PM
specONE
specONE's Avatar
I have connections to get wiring diagrams for the rain sensors. Give me a couple of days
Old 05-08-16, 10:58 PM
specONE
specONE's Avatar
Originally Posted by PatrixUSA
No need to wait, this might be what you're looking for. Based on my amateur eye (don't ask me to decipher any this) but looks like the rain sensing component / wiring is a separate unit / bundle? Use at your own discretion.
Can you also provide the pages with the connector plug pinout numbering?
Old 05-09-16, 07:26 AM
specONE
specONE's Avatar
Do not have connector pin diagrams for the wiper / washer subsystem, only wiring as provided.
OK here's my contribution.
Looks slightly different than one you provided.
I'll study it more when I have a sit down time
My Quick assessment , What we are looking for is a 3 wire plug for the rain sensor. Main wire necessary is the mpx wire and if it the plug doesn't exist we can just run it ourselves to any of the mpx network wires in the car to get it working
@Edwin8484 let me know what you come up with if you discover anything before me
File Type: pdf
Old 05-09-16, 08:19 AM
specONE
specONE's Avatar
The diagram you've provided looks like the diagram for systems without the rain sensor, I provided the wiring diagram with the rain sensor component. That's the difference I believe.
Look again. Rain sensor is on page 1 of mines
Old 05-09-16, 01:38 PM
Vivid101
Vivid101's Avatar
the real question is, how bad do your new foglight blind everyone that is in front of your car?
Old 05-10-16, 08:13 AM
Edwin8484
Edwin8484's Avatar
Thank you specOne and PatrixUSA. I will start investigating about this in a couple of weeks once I'm done with finals.
Old 05-10-16, 08:14 AM
dnasians
dnasians's Avatar
so... foglights are plug and play with the stalk.... that means that there should be wiring there and available that supplies power, and we can use those wires to hook up for an aftermarket switch... right?
Old 05-10-16, 08:18 AM
Edwin8484
Edwin8484's Avatar
Foglights are not meant to blind people. The ones I have and the JDM Foglights are adjustable (up and Down) so that makes it up to me or the installer to make sure the lights are not blinding to others. Even if the light output is intense. Unfortunately that light output of the Foglights I bought are very not strong enough to my liking
Old 05-10-16, 08:28 AM
Edwin8484
Edwin8484's Avatar
Yes, when you add the new stalk make sure that you see 3 wires going into the black female harness on prungs 9-11. I think wires are colored white, white/black and pink.
The wires for the Foglights should be tucked inside the bumper area close to where the Foglights are suppose to go. The color of the harbes is black and the inside looks green. Look at my pictures and follow that. I hope all of our cars come prewired the same.
Old 05-10-16, 09:08 AM
Cthan3o3
Cthan3o3's Avatar
Edwin, how are you liking your eBay fog lights so far? How is the fitment of the fog shrouds? And how well do they match the headlights?
Old 05-10-16, 09:53 AM
specONE
specONE's Avatar
For the Rain sensor retrofit we are investigating into,
something i just thought of, One thing to be concern about with the Rain sensor is that the placement on the windshield, on cars with this options its typically a portion of the dot matrix near the rear view mirror that is clear and the sensor is stuck onto the wind shield to view clearly through without obstruction.
On our Fsport windshield, it is all dot matrix around the mirror area. We can obviously mounted off to the side not in a stock location but it will not look as good.
Old 05-10-16, 10:16 AM
dnasians
dnasians's Avatar
if i were to use an aftermarket switch (where the blank dead switches are) could i wire it through there?
Old 05-10-16, 11:41 AM
SummerRain
SummerRain's Avatar
Did some research and I believe these are the part numbers for the stalk
8465230690 - Wiper switch w/ rain sensing
8465230681 - Wiper switch w/o rain sensing
8414030360 - Headlight switch w/ fog light
8414030420 - Headlight switch w/o fog light
Parts actually share with GS
Old 05-10-16, 01:06 PM
specONE
specONE's Avatar
I was assuming that it would be shared with GS and RC as well.
There are probably a lot of parts that are interchangeable between GS and IS
Old 05-11-16, 11:29 AM
SummerRain
SummerRain's Avatar
It's off the topic but it will be nice if we can get auto high beam working on the F-sport =]
What sensor is it using?
Quick Reply: Plug&Play F-Sport Foglights/Auto Wipers (DIY)
