Hidden menus?
Hidden menus?
Are there any hidden menus in the nav system? I know there were on my Scions.
I have pressed and held Menu then switched the parking lights on off 5 times. That let me run some tests. Is there anyway to make adjustments to the audio too?
Also has any of you been able to turn on a setting where it lets you roll your windows up by holding the lock bottom on your keyfob? The dealer was only able to turn on windows down with unlock
You can install it no problem Windows is backwards compatible, as long as you get the 64 bit version. Feel free to PM me if you have any other questions. No point in getting a computer science degree if you can't put it to use.
Yeah I'll send you a PM so I can do this. I have the mini dvic cable somewhere but I know it was only compatible with 32bit I have to find it though. I also have to find a way to get the software and drivers. I'll send you a pm
Carista only allows LPS to be set, along with OBDII codes to be read and reset. TIS can read diagnostic logs, update firmware and set other custom settings that Carista can't.
