Auto windows with the remote?
I thought I remember reading somewhere on here that the functionality is there it just needs to be programmed by the dealer, is that correct? When you hold down unlock on the remote the windows roll down and then when you hold lock the windows roll back up ...
Thanks!
Thanks!
Key fob can only be programmed to roll down windows
I just ordered a Carista Bluetooth OBD2 adapter from Amazon: Link: http://amzn.com/B00YVHGTBM
You'll also need their app for Android or iPhone - it's free to look at the settings and ODB stuff, but you'll have to purchase the Pro version of the app for $20 to be able to change the car's settings. It should arrive today - I'll report back after I've had a chance to use it.
The Carista was delivered and I got a chance to use it. As expected, I had to purchase the Pro upgrade for the app for $19.99, but it worked like a charm.
WOW! I had no idea there were so many adjustments that I now have available! It has a feature that will email your settings to you. Here's the email that shows all the things you can adjust (2015 IS350). These are also the factory settings.
Doors / Windows / Remote
Blink turn signals when locking/unlocking with remote *YES* / NO
Beep when locking/unlocking with remote *YES* / NO
Volume of beep when locking/unocking with remote OFF / 1/ 2 / 3 / 4 / *5* / 6 / MAX
Beep when opening/closing windows with remote *YES* / NO
Warn when door can't be locked with remote because it'sopen *YES* / NO
Warn when a window is still open when locking doors *YES* / NO
Warn when sunroof is still open when locking doors *YES* / NO
Panic function on remote *ENABLED* / DISABLED
Open trunk lid with remote
SINGLE CLICK / DOUBLE CLICK / *LONG PRESS* / VERY LONGPRESS / DISABLED
Re-lock doors automatically if you unlock, but don't opena door *YES* / NO
Re-lock doors automatically if you unlock, but don't opena door within…
30 SECONDS / *60 SECONDS* / 120 SECONDS
Unlock doors via remote
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON1ST PRESS
Unlock doors via physical key
Unlock doors via smart key (door handle button)
*DRIVER'SDOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Auto-lock all doors
DISABLED / *WHEN SHIFTING INTO GEAR* / WHEN VEHICLESTARTS MOVING
Auto-unlock all doors
DISABLED / WHEN SHIFTING INTO PARK (P) / *WHEN DRIVER'SDOOR IS OPENED*
Unlock trunk when doors are unlocked *ON* / OFF
After locking with smart key, allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
Smart key location to start car FRONT SEATS / *ANYWHERE IN VEHICLE*
Unlock trunk when smart key in range *YES* / NO
Open windows and sunroof by holding key in door lock ON /*OFF*
Close windows and sunroof by holding key in door lock ON/ *OFF*
Open windows and sunroof via long-press on remote ON /*OFF*
Lower passenger-side mirror when in reverse gear (req.memory seats)
DEFAULT / *USER-SPECIFIED*
Instruments / Display / Dings
Engine start indicator *ON* / OFF
Display odometer after ignition is turned off for…
*30 SECONDS* / 1 MINUTE / 10 MINUTES / OFF
Ding when headlights are left on *YES* / NO
Seat belt warning ding (driver) *ENABLED* / DISABLED
Seat belt warning ding (front passenger) *ENABLED* / DISABLED
Turn signal click volume LOW / *MEDIUM* / HIGH
Remote low battery warning *ON* / OFF
Lights
Daytime running lights *ON* / OFF
Coming-home lights duration
OFF / *30 SECONDS* / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
Turn on marker lights when vehicle is unlocked via remote *ON* / OFF
Instrument lights dimming sensitivity
Instrument lights restoring sensitivity
Dim interior lights after… 7 SECONDS / *15 SECONDS* / 30 SECONDS
Turn on interior lights when you shut off engine *YES* / NO
Turn on interior lights when you unlock doors *YES* / NO
Turn on interior lights when smart key in range *YES* / NO
Turn on interior door-handle & center console lightsdimly (flood lights) when ignition is on and shifter is not in park (P) *YES* / NO
Turn on exterior footlight (on side mirror) when smartkey in range *YES* / NO
Turn on exterior footlight (on side mirror) when doorsunlocked via remote *YES* / NO
Turn on exterior footlight (on side mirror) for…
OFF / 7SECONDS / *15 SECONDS* / 30 SECONDS
Interior lights linked to footlight *YES* / NO
Interior light control *ENABLED* / DISABLED
Exterior light control *ENABLED* / DISABLED
Heater & A/C
Temperature dial calibration -2°C / -1°C / *NORMAL* / +1°C / +2°C
Ambient temperature calibration
-3°C / -2°C / -1°C / *NORMAL* / +1°C / +2°C / +3°C
A/C evaporator control *AUTOMATIC* / MANUAL
A/C ECO mode *ENABLED* / DISABLED
Auto-increase blower speed when front defroster is on *YES* / NO
Auto-turn on A/C when AUTO button pressed (if needed) *YES* / NO
Deactivate front defroster when AUTO button pressed *YES* / NO
Also blow to feet in "face" mode *YES* / NO
Seat heater mode AUTOMATIC / *MANUAL*
Fan speed reaches its target… SLOWLY / *NORMALLY* / FAST
Other
Roll down rear shade when in reverse gear *YES* / NO
Delay for rolling down rear shade when in reverse gear
IMMEDIATE / *0.7 SECONDS* / 0.9 SECONDS / 1.2 SECONDS
Obtained with Carista 2.6 for iOS.
Auto-lock all doors
Lights
Heater & A/C
Other
Auto-lock all doors
Lights
Heater & A/C
Other
Auto-lock all doors
Lights
Heater & A/C
Other
Post videos of this magic now!
Ps, did u know you can downshift via paddles in any of the 4 drive modes?! Lol
How did you activated it? Did you take it to the dealer and had them do it for you? Or did you do it on your own with the Techstream or the app mentioned above?
