Non Mark Levinson sound (do I have options)
Old 05-30-16, 11:41 PM
etutwiler
etutwiler's Avatar
Default Non Mark Levinson sound (do I have options)
From what I see no options exist to have a decent sounding system. Anyone have a work a round yet?
Old 05-31-16, 06:58 AM
Mike200T
Mike200T's Avatar
What are you looking for? "work around" ... for what? If you don't like the factory speakers change them and add a sub ... not sure what you're looking for ...
Old 05-31-16, 07:03 AM
Kevin350
Kevin350's Avatar
It's either ML system or base. If you get base and want better sound then you have to upgrade with aftermarket speakers and sub.
Old 05-31-16, 11:05 AM
Rebirthing
Rebirthing's Avatar
There is no workaround to install ML system into your base.
An aftermarket system is your best choice.
Old 05-31-16, 01:21 PM
etutwiler
etutwiler's Avatar
My initial post was a poor description of my inquiry.
I am by no means an audiophile but the sound is flat and it lacks real clarity. I am not looking for increased bass but better clarity.
Through several posts here it looked like this was near impossible with this car. You can't take full advantage of better sound without changing the head unit (which is near impossible). I was under the impression that putting new speakers and amps would be a waste of money for the minutia of performance one gets.
Old 05-31-16, 01:40 PM
Mike200T
Mike200T's Avatar
With the right amount of money, anything is possible. I'm sure new speakers, amps and eq's will give you the sound you want. It all depends on how much money you want to spend to get that sound. You might want to consult a local audio shop and see what they say.
Old 06-01-16, 11:42 PM
qbanghost
qbanghost's Avatar
i think the sound my f sport brings is great sound i dont even mess around with the base because is pretty damn loud as is but good luck brother. Anything higher than what I it comes with and I might as well put some 24" roms on the lexus to blend in right lol.
Old 06-02-16, 01:28 AM
CriMe
CriMe's Avatar
I do agree with you that the sound from the non ML system is a bit on the flat side. You can leave the stock HU and add a processor and amp (s). This is the route that I went. I added the Audiocontrol DQ-61, JL amp for my sub, and a second JL amp for my door speakers, which I replaced with JL C5's. Sounds amazing. Gets loud enough to make my ears bleed, yet sounds clear as a bell at those volumes - not that I'm in to that sort of thing, but it's nice to know that the potential is there.
Old 06-02-16, 05:09 PM
etutwiler
etutwiler's Avatar
Thank you but as stated previously, I am not looking for more bass.
Thank-you for the advice! I will look into that!
Old 06-02-16, 05:46 PM
Ice350
Ice350's Avatar
When I was younger, I wanted super high clarity along with low thump when needed. I would change setting in the middle of songs depending on which instruments were being highlighted. I don't sit in cars and listen to music anymore but I still want good sound for the ride.
All my Lexus cars I have added a subwoofer and amp. I have not changed speakers because I'm not into it that deeply anymore....but I'm happy with what it does.
Mark Levinson audio has gotten better lately and I would consider buying a car so equipped but I doubt I would get the performance I have from doing it my way.
Old 11-30-18, 03:51 PM
sixbanger
sixbanger's Avatar
I upgraded the center channel, that seemed to help. cheap 4" mb quart coaxial. cleaned up the vocals a bit, making it more tolerable for now
Old 11-30-18, 04:00 PM
sixbanger
sixbanger's Avatar
Old 12-01-18, 09:33 AM
osiriskidd
osiriskidd's Avatar
Originally Posted by sixbanger
what speaker model and size is that?
Old 12-01-18, 09:41 AM
sixbanger
sixbanger's Avatar
Old 12-01-18, 09:44 AM
sixbanger
sixbanger's Avatar
This same speaker fits in the left and right dash locations. I just ordered an additional pair
Quick Reply: Non Mark Levinson sound (do I have options)
