Alert: Nav system locking up
Old 06-07-16, 03:31 PM
  #46
anthonys2r
anthonys2r's Avatar
Worked fine this morning and fine on my short drive at 2 pm to the post office. Started looping after I got gas 15 minutes later.
edit: 2015 IS350 F-Sport with Nav/ML
Old 06-07-16, 03:37 PM
  #47
Mrg02d
Mrg02d's Avatar
What year? Mines a 2014.
Old 06-07-16, 03:43 PM
  #48
Thang
Thang's Avatar
Found an article here: http://www.bloomberg.com/news/articl...gation-systems
Old 06-07-16, 03:46 PM
  #49
ARM350F
ARM350F's Avatar
It happened to me, I did the reset which fixed it then turned the car off for about 30 minutes and went back to it and it worked fine. I'm in LA if that helps anyone
Old 06-07-16, 03:55 PM
  #50
shadykev
shadykev's Avatar
Wtf happened to me this morning? Is there a solution
Edit: just saw the article few posts up
Old 06-07-16, 04:13 PM
  #51
momo15
momo15's Avatar
I turned off and turned on car twice and the nav still works after the battery reset.
Old 06-07-16, 04:29 PM
  #52
dstopsie
dstopsie's Avatar
There is no solution yet my service advisor told me that if you bring the car in and they disconnect the battery and do a hard reboot of the system about an hour later it just returns to the same screen. I called the Lexus support line and the guy told me that their engineers are where of it they are working on a six and they will send out an email or something the customers to let them know what they need to do it could result in in cars having to go to the dealer to be fixed which is the most ridiculous thing I've ever heard they can't just do it over the air they screwed it up over the air why can't they fix it over the air. I have the 2015 RC 350
Old 06-07-16, 04:31 PM
  #53
dstopsie
dstopsie's Avatar
What do you mean by you did the reset did you disconnect your battery?
Old 06-07-16, 04:35 PM
  #54
Ray20213
Ray20213's Avatar
Default Nav screen out
Just a heads up guys if your NAV screen is out like mine is you have to stop by the dealership to reboot the system ....they're having a problem with the 2015 and 2016 ALL models you have to bring it to the dealer and they have to reboot the system it takes about an hour BUT beware I stoped by the dealer today and I was about 35 cars in the service drive Ahead of me so I suggest making an appointment !!!
Old 06-07-16, 04:41 PM
  #55
dstopsie
dstopsie's Avatar
Hi see the other threads on the subject it's not as easy as just stopping by the dealer and letting them fix it because the dealer told me after about an hour or two of them rebooting the system it's just going back it's a nationwide problem according to Lexus because I called them and they do not have a solution to it yet
Old 06-07-16, 04:49 PM
  #56
EJ255t
EJ255t's Avatar
ya, i just had mine replaced actually!!! but yes if your nav screen keeps freezing and restarting, it most likley just needs a software update!!
Old 06-07-16, 04:50 PM
  #57
msgs350
msgs350's Avatar
This sucks if a dealership visit is required. I would expect a lot of cars lined up for this re-boot.
Anyone know what the cause is?
  #58
gregerst
gregerst's Avatar
so I guess I'm not the only one having this issue. I've had the car a year without this issue and suddenly today after leaving work the nav goes into a continuous reboot cycle. first thing i did when i got home was disconnect the battery for about 15 minutes. it seems to have solved it.. wth?
Old 06-07-16, 04:51 PM
  #59
ARM350F
ARM350F's Avatar
Yes I disconnected the battery
Old 06-07-16, 04:53 PM
  #60
sdotk
sdotk's Avatar
2014 here. It was fine this morning 7 am pacific and fine again at 3:10. Having issues now at 4:45pm pacific. Will try the reset when I get home. My nav keeps cycling thru the first three screens
Quick Reply: Alert: Nav system locking up
