Window Rolling Up Problem
Hey everyone!
I encountered a really odd problem when rolling up the right rear window. Every time I would roll it up all the way it would go back down by itself. It doesn't matter whether I use the switch on that door or the driver's door. There is nothing obstructing it whatsoever. Has this happened to anyone else?
Here's a video:
Here's a video:
Have you disconnected the battery recently? Go to the window switch (on the individual door) and wind the window down, then wind it back up, holding the switch for a few seconds after it is fully up. If your battery was disconnected this should reset the window. If it wasn't disconnected, then there might be something else amiss.
