JoeZ + invidia midpipe fitment issue
Old 06-26-16 | 08:06 PM
LeeJonah's Avatar
LeeJonah
Default JoeZ + invidia midpipe fitment issue
So i recently got an invidia midpipe paired with my JoeZ axle back.Its been rattling a bit and finally decided to look at it. Seems like the JoeZ is hitting a hanger or hook or some sort.
Is anyone else having this problem?
Also was wondering, when installing a JoeZ axle back onto the invidia midpipe, what bolts/nuts and gaskets did you guys use because the OEM donut gaskets and screws did not fit. So the mechanic used other parts to make it work. I bought both JoeZ and Invidia used so I'm not sure what accessories came with what.
Thanks!
Heres a pic of what the JoeZ is hitting. (the black thing on the top)
Old 06-26-16 | 10:38 PM
jay90011's Avatar
jay90011
I had the same issue with the tsudo and joez combo. I ended up bending that inner black hanger up away from the muffler. Fixed the issue and it did not change the exhaust height because only the tip of the hanger is being bent up. The tsudo midpipe came with its own spring loaded bolts and donut so I don't have the pairing issue you have.
Old 06-27-16 | 07:53 PM
leo877's Avatar
leo877
OP, I have the same set up but I do not have this problem. You can try to adjust the muffler to get it fix. Here is a clip that I made after the installation.
Old 06-28-16 | 11:43 PM
MWIS350's Avatar
MWIS350
It's normal I have Tanabe Axleback and Invidia midepipe.
Old 06-29-16 | 01:25 AM
LeeJonah's Avatar
LeeJonah
Hey guys thanks for all he reply. I did quick fix not sure about long term but i just simply duct taped the hanger, probably still hits, but at least i don't hear it anymore!
Old 06-29-16 | 03:31 PM
Silver09IS's Avatar
Silver09IS
Ayy at least you got creative haha lets see how long it lasts tho!
Old 03-27-18 | 08:04 AM
Ciggy's Avatar
Ciggy
I believe I have this exact issue rite now. It's extremely loud. Going to get on ramps today and try to solve.
Edit: for info - Apexi mid-pipe with an F-sport axle back. 2014 IS350 AWD.
Old 03-27-18 | 01:18 PM
Ciggy's Avatar
Ciggy
Bent up the hangers on both sides. "Installed" a piece of gorilla tape to the end of each in case it does make contact again.
Old 03-27-18 | 02:09 PM
CLUM's Avatar
CLUM
I'd be interested to see what JoeZ has to say about this? Does he blame it on the non-OE mid pipe or is it a faulty design?
I'd wrap the chassis hanger with a few layers of fiberglass heat tape/wrap. Maybe even get a rubber cap and put it on the end of the hanger and then wrap it with heat wrap...
Old 03-27-18 | 02:32 PM
Ciggy's Avatar
Ciggy
My set up is Apexi and stock f-sport. A rubber cap on the end of the hanger would have solved the noise also but bending them up and away was just as effective.
Old 03-28-18 | 12:56 PM
Darqhelmet's Avatar
Darqhelmet
Just slide the muffler forward. That is pushed to far back on the factory hanger.
Boombai
06-22-17 11:54 AM
mikexay
03-08-17 03:10 PM
Ktran1039
Performance
02-16-16 11:47 AM
wiliu0
05-17-15 10:54 PM
White350
Performance
48
02-07-12 11:19 AM
