Does aftermarket air intakes for 3IS actually produce any gains?
#46
Former Sponsor
I just saw a video from MightyCarMods on YouTube, where they dyno'd a stock air filter vs. performance filter. The result showed absolutely no gains.
And also based on where I live (Dubai), these performance filters and intakes could ruin my engine due to the amount of loose sand thats in the air. And, sometimes we get sandstorms and that just increases the chances of contaminants in the engine. This is my only car and I drive it a lot and intend to keep it for a little bit longer. So I plan very carefully before I make any modifications.
Now if you look at any V8 LS series car, for example the Corvette, those motors react extremely well to bolt ons.
For your conditions seems like drop in filter and would suit your needs if you really wanted to change something out. You should also look into maybe changing out the intake arm, ridges in the plastic arm doesn't flow as well as a smooth pipe... so basically a F sport intake
ISFSCOTT
IS F (2008-2014)
11-30-16 07:22 AM
