Lc2i ML system
Has anyone used a lc2i (line output converter) on their ML system? I'm looking for a wiring diagram to use and reviews on how well they like it with and without an aftermarket subwoofer.
It would be nice to have a single go-to thread to answer everyone's questions about the lc2i and how to properly install an aftermarket amp tapping into the correct wires.
If you're just looking to add a subwoofer, don't forget you can buy amplifiers that have high-level inputs and tap directly off the subwoofer poles or the high-side speaker wires on the high-side of the amp.
I did it this way with this amp:
http://www.jlaudio.com/jx500-1d-car-...plifiers-99400
Much simpler install and much less junk in the trunk.
I plan on running a 12" sub but still want to be able to have the stock 10" sub sound good when I turn the bass **** down because it sounds super distorted when the radio is past 30
BumpMaster
06-12-14 08:34 AM
305Busa
05-06-13 07:30 PM
