Homelink in my IS200T won't work on my townhome community gate
I am trying to get Homelink in my car to work on my townhome community gate but am having no luck. If someone has been able to get it to work can you please post your exact steps. I even went on the Homelink website and tried their steps with no luck. Please assist, thank you.
Various Steps tried with no luck:
- Using both hands, simultaneously press and hold both the desired HomeLink button and the gate operator handheld transmitter button. Continue to press and hold the HomeLink button while you press and re-press ("cycle") your handheld transmitter every two seconds until the frequency signal has been learned.
And also
- Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
And also
If it's rolling code, you wouldn't be able to learn it off the handheld transmitter since the rolling code is tied to that particular transmitter to the opener.
You would need to get it learned from the actual gate opener itself as if were a regular garage door opener with rolling code if I am correct.
Edit:
I find that the Homelink instructions are not quite correct or accurate. I found that out when following the instructions which said, learn something along the lines of getting it off the remote for rolling code which it definitely did not work. Used the learn button from the garage door opener and it work perfectly.
Edit:
Edit:
Edit:
unfortunately there is no security at my townhome community gate so there is no one to ask. I will try to see if I can look at the the gate area that raises the arm to see if I can see a learn button.
Try to find the person or company which manages the particular gate because they would most likely be your best resource.
minlite
NX - 1st Gen (2015-2021)
08-31-16 04:19 PM
