Maintenance req light already?
My 2016 is200t is at 4500 miles and I got the maint req soon light pop up already? I thought we only had to get an oil change at 10k miles, which would be the first service.
Whats involved in this 5k service? Can I just have this maint light turned off? lol, sorry, I dont remember anyone telling me about any 5k service when buying the car and assumed the first service was at 10k. I'll read the manual when I get a chance. thanks
- Rotate Tires
- Inspect /Adjust All Fluid Levels
- Check Installation Of Driver's Floor Mat
- Inspect Wiper Blades
- Perform Road-Test on Vehicle
- Program Lexus Personalized Settings, If Requested
- Reset Maintenance Reminder Light
- Visually Inspect Brake Pads, Calipers and Rotors
Yes, you can turn off the reminder yourself. Here's the instruction: http://lexus2.custhelp.com/app/answe...ument-panel%3F
It's just a precaution for non-car people (99% of lexus drivers)
On my CT200h, I just ignored it. I can rotate my own damn tires. =)
I mean yeah you can still drive it. But the light will be on and you will be getting that maintenance message every time you start the car. And if something goes wrong with your car in between the 5k-10k miles, Lexus would be like, "Well you didn't come for the 5k check up, so you probably F-ed something up, so its not the manufacturers fault".
Technically, 5K is a check-up to make sure everything is working and such from the factory.
Everything they do at 10k service except for the oil change.
- Rotate Tires
For 14-15, the standard IS250 and IS350 without upgraded tire packages had a square setup. I am not sure about the 200t setup. For 16, Lexus made the 18" staggered upgrade on the 350 standard. So while most have the staggered setup, some do not.
This. Can rotate tires on non-F Sport cars and cannot rotate on F Sport cars, There may be other packages that have a staggered set up too, but I am not specifically aware of them. The best value for me for the 5K service was to reset the service light. I didn't even care for the car wash with my 250 because there was tire grease all over the side of the car when I got home.
Muti007
05-29-11 03:51 AM
