Rusty rock chips
Hey guys,
What would be the best way to tackle these rock chips? The rusted one is located on top of my windshield and the other on the bottom of my front bumper. I'm more worried about the rusted one and how to go about getting rid of the rust.
The first chip you posted has probably been exposed to the elements for some time (or you live in a fairly corrosive environment). It's best to get these tackled as soon as possible to prevent the rust from chipping away at the surrounding paint. The second chip on your bumper is cosmetic. Our plastic bumpers don't rust.
Everyone has their preferred paint touch up brand, but I always goes with OEM. Just bring your paint code is (which is shown on the VIN label on the driver's door).
This is one of the best videos I've found on touching up paint chips. 95% of the work is the prep, not the actual painting process. I'm sure our detailing forums on here have equally good advice too.
Any steel exposed will rust. doesnt matter what year it is. Steel starts rusting the nano second its exposed. The paint has been chipped off.
Go to your local auto parts store and get a pearl white paint pen (assuming your car is pearl white)--find a Toyota/Lexus one but if not, any brand should be close enough. They usually will have a tip at the end thats used to scratch off rust/corrosion -- look for those types.
Then you basically dig out all the rust. You'll need to work the area surrounding the rust spot. So you'll need to dig out a little bit of paint to sand off ALL the rust. Then wipe it with alcohol and check again to make sure you got all of it.
Then paint over it slowly and methodically until you put enough paint to be level with the rest of the car. Then go over it with clear once it dries.
Thats the best thing to do short of respraying the whole roof.
always take care of chips asap.
I have three of these on my '14 that are rusted like that. Same spot. I was going to hole punch some sandpaper (1000 grit), crazy glue a couple to the eraser of a pencil and use that to sand off any rust before dabbing/blobbing some touch up paint on with a really small straw, rolled up paper or toothpick.
Off topic..
But for chips that shows the black layer underneath (I'm assuming its the primer coating). Will these rust as well?
I've got a few on my 2016 IS350 in Ultra White.
Note: I live in the Bay Area, CA, will be climate affect rusting?
As long as bare steel is not exposed, it won't rust. Still, I'd paint it. Dont give rust the tiniest chance to rear its ugly head.
Check out a paint pen like this: http://amzn.to/2cA24KX
Don't worry about the color not being exact. As long as you're close, it'll work. The trick with this pen is it comes with a little sharp edge tool where you use to sand away the rust. You use it like you're using a pen to write. And it comes w/ clear coat. Way cheaper than the dealer.
Black for black, white for white, silver for silver. More specialized colors like Blue Mica may be harder but I'm sure you can find blue. This is for the occasional chip. you wont be repainting your whole car so 100% color match isn't a big deal. Did this on my silver BMW using a generic Toyota silver and it worked brilliantly to hide all my rock chips.
That is so fast, as OP's car is a 15. I notice you and OP are in a northern climates. I guess the speed at which rust starts must be climate and road treatments dependent, as I'm sure they salt your roads due to snow and ice. I have many of these small chips down to bare metal (thank you California freeways) on my 14 and have no rust. I failed to account for how road chemicals would greatly speed up the oxidation process.
Ever wash your car and see the rotors instantly rust? Or the brakes stick to the rotors when you drive away the morning after you wash your car? That's cause the rusting already began and welded itself to the raw steel rotors.
When you drive your car daily, you don't see this rust because the pads constantly wipe it away preventing it from building up.
