How to install LED Turn Signals in your 3IS! (Bright, safe, and proper LEDs)
Old 08-15-18 | 05:21 PM
  #91
Flash5's Avatar
Flash5
Originally Posted by t0md3long3
i dont know i didnt open it yet, yeah im asking about mirror tun lights.
You should be able to tell the difference between LED and Halogens without taking anything apart.
Old 08-22-18 | 04:44 PM
  #92
t0md3long3's Avatar
t0md3long3
quick question, rear license plate lights are LED already in lex 2016 f sport?
Old 08-22-18 | 05:04 PM
  #93
Flash5's Avatar
Flash5
They should be. Mine are LED stock.
Old 03-24-19 | 11:31 PM
  #94
Sdxplicit's Avatar
Sdxplicit
Originally Posted by wforty94
do you have the link to purchase the hyper white front blinker bulbs as shown in your video? I would like to use those over the amber.
if i just wanted to do the LED fronts and leave the rears alone, i wouldn't need the resistors at all?
You will still need load resistors just for front LEDs. I tried and got hyper blink.
Old 03-27-19 | 03:47 PM
  #95
arentz07's Avatar
arentz07
The mirror turning indicators are LED on all 3rd-gen IS trims.
The puddle lights are halogen.
Old 03-27-19 | 04:01 PM
  #96
Sdxplicit's Avatar
Sdxplicit
Revised. Followed instructions and only installed one set of resistors to rear signals and no hyper flash. I am assuming it is the led bulbs you used. If you used the ones suggested, you only need 1 set of resistors.
Old 03-28-19 | 05:07 PM
  #97
AtomicAWD's Avatar
AtomicAWD
So will not these accomplish it, and much more easily?
Amazon Amazon
Old 03-28-19 | 05:52 PM
  #98
Sdxplicit's Avatar
Sdxplicit
https://www.amazon.com/VehiCode-Brig...dp/B07GW5B21R/
If you read your product description, it says "load resistors included to solve hyper blink". So yes it will solve it, but you still have to install load resistors
Old 04-01-19 | 07:01 PM
  #99
ex00's Avatar
ex00
Got my LEDs from LastFit
They have resistors built-in so no splicing at all.
Old 04-02-19 | 12:37 PM
  #100
Sonn's Avatar
Sonn
You guys should try sequential turn signal I have seen people mod the drl with sequential turn signal like the new Lexus.
Old 04-13-19 | 03:07 PM
  #101
ex00's Avatar
ex00
That is very expensive to get done but it does look cool.
Old 08-13-19 | 08:09 AM
  #102
sml7781's Avatar
sml7781
I have had good luck with my 2015 IS 350 using these front and back with no hyperflash
https://www.amazon.com/gp/product/B07Q8RZRZV/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07Q8RZRZV/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
They only start to hyperflash when they are in use for about 3 minutes straight. Under normal use you won't see any hyperflash. Overall plug and play, priced good with built in load resistors and very bright.
Old 06-18-20 | 10:05 PM
  #103
GR3Y5H3ART's Avatar
GR3Y5H3ART
just did mine from Sylvania Silver Stars White to LED White Turn Signals....only thing, from past experience, Resistors get hot so rather adding that heat to the wire loom, I mounted mine with double sided tape to the frame to keep it cooler:
How to install LED Turn Signals in your 3IS! (Bright, safe, and proper LEDs)-iqalij7.jpg
How to install LED Turn Signals in your 3IS! (Bright, safe, and proper LEDs)-biodkrp.jpg
my favorite double sided Mounting Tape
How to install LED Turn Signals in your 3IS! (Bright, safe, and proper LEDs)-96utqsv.jpg
side note: get these ones, not sure if 50W8 would work but the Philips i had didn't work:
How to install LED Turn Signals in your 3IS! (Bright, safe, and proper LEDs)-ms09afo.jpg
Doesn't work on 3IS, depends on Bulb too but i would get something else
Amazon Amazon
KennyZ
02-20-18 09:27 AM
TRACKMKIII
GS - 1st Gen (1993-1997)
01-09-15 07:17 PM
djdoughboy
03-29-06 04:25 PM
whatuusay1
Lighting
10-12-03 12:31 AM
