2015 IS350 F-Sport All Wheel Drive - Tire Wear Situation
Yesterday I pickup up a nasty metal shard which resulted in an immediate flat LR tire. Upon removal, I found the inside edge of the tire had significant exposed steel belting. (!) Check the RR tire, found exactly the same, about 80% of the perimeter had a raw edge of steel belting. The front tires have nothing of this, they have some normal type wear. 43,000 miles, 23 month old car. I drive a pretty normal commute, only very occasional, very limited spirited driving. 90% of the time I'm alone in the vehicle, 200lbs, only very occasional loading beyond 20 lbs of stuff.
The rear tire wear seems unusual to me, has anyone else had a similar condition?
Looks like the tires are dry rotted. That shard was a blessing in disguise. It made you inspect your rotting tires which are ready to blow at any second.
Get a new set.
This is a performance oriented car. All you guys' tires should be inspected regularly and in tip top rubbery soft grippy shape. Your tires should be priority 1. Go check yours NOW
Get a new set.
Get a new set.
Get a new set.
That’s scary. Do you run your car through automatic car washes on a regular basis? Based on the markings on your tire and the rash on your rim’s inside lip, (and the fact that your tread depth looks ok) it looks like the tire guide of an automatic car wash has put significant pressure on the inside portion of your rear tires, pressing the rim protector ridge in even with the rim with enough repeated force to cause that break in the rubber and possible belt breakage. I’d have a dealer or tire shop inspect all and replace as needed. This would also explain why fronts are ok, as they are narrower than rear. Keep us posted on what you find out.
It happened on both lh and rh very similarly, while the car washes I visit have only a lh-only wheel guide rail.
So with no sidewall markings, and 80% of the perimeter on both sides showing the condition, tire construction and/or alignment issues would seem to be at the top of the list. Although this too seems unlikely...
Anyway I put on 4 new Michelins which are doing fine. Alignment was checked, the numbers were all surprisingly close to mid-range in all areas. Of course I will monitor the wear of the new shoes.
btw for reference, the dealer quoted $1,55x for 4 new Turanzas. At Belle Tire the Turanzas were quoted at $1,2xx, I paid $1,050 for the Michelins. (I would have paid more for the Michelins than for the Turanzas!)
Not to revive an old thread here, but I had posted before having the same issue with my 2017 300awd. I’ve purchased some upper camber arms for the adjustment of it in the rear. I’ve yet to get them installed, but I will post again so others may be able to avoid future issues as well. I thought it was weird too that only the rears wore this way. Alignment checked out good when I put new tires on, but they agreed, it wouldn’t hurt to add the extra adjustment.
Received 1,737 Likes
Get two new tires and check the alignment. No point speculating until you know what's what with the rear.
And the only way to know that is to get two news tires and do an alignment.
That’s exactly what I’ve done, only way to know for sure. So far though I’ve driven 2,400mi with them. With measuring the inside vs outside on the rear, the wear is still there, using simple calipers with depth measurement. It’s wearing more on the passenger than the driver side, but it is still accelerated wear on the far insides, like the factory tires. Something is off for certain though, just hoping these parts will help to correct it. Wish it were in the front like most everyone else has, at least then I’d know what to do with it, as others have. I will post once I have them on and with more measurements as the miles go.
Panzer126
02-12-17 03:31 PM
sumohax0r
02-20-15 07:10 PM
