Who will be the first to retrofit the 2017 IS screen in the 2014-16 IS models
Not gonna lie, I thought of this when I first saw the 17. I just see this big *** area with a little screen. I'm just wondering if no one in lexus thought of using that opportunity to use the entire area for the screen. Kinda a wasted potential but no discredit to the is350. I'm loving this car. But like most of us, always looking for ways to improve.
In theory all we want is the screen. The question is will the wiring and size fit? Resolution will have to be considered being the fact that comes from the actual radio itself
Interested in doing this as well but you all know that it will be very expensive mod. Screen alone already cost about $2400 for '14-'16 MY. You will likely have to mod the engine push start button area too, not even sure it's possible. In '17 model it was reshaped so that driver can see the corner of the bigger size screen.
Didn't they revise the dash trim pieces to not block the big screen as well? Also the new control pad with the added buttons seems like it's not going to be a simple retrofit. Nevertheless I would be very interested to see someone tackle it.
Yes, it was revised for '17 model but if you're going to fit the bigger screen to our older cars it will be partially blocked.
As much as I love that bigger screen, it'll be too expensive and difficult for anyone to attempt.
Not to mention, the 2014-2016 IS infotainment software probably won't know what to do with the screen. You'd need a way to get the new hardware and/or flash the new software on there. Overall, it's a project that'll probably have a very high cost/benefit ratio. For the price to do it, you could probably just sell your IS and buy a 2017.
Existing head unit wouldn't know what to do with the screen. Software is written to display at one resolution only I bet.
Coupler to connect it may be entirely different. It could be from a whole different supplier with entirely new PCB.
I foresee the radio will have to be swapped as well, and then it goes on and on, dash center console, joystick, maybe even amplifier. It will be an expensive project. Will be more worth while after the car gets a little older and some of these get into accidents and totaled and then you get get parts from it used.
