TPMS Canister on 3IS
Ok, so I spent an entire day at a tire shop this past weekend, tried out various makes/brands/models of TPMS' with either cloned ID's from stock sensors or just sensors which came with different ID's... none of which will get the warning light to come off, and none of which will display pressure on the dash. Only the stock ones seems to work...
Also, noticed another thing is with the stock sensors, they MUST be located near each corner of the car in order for them to read pressures. If you just stick them all together, the pressure will not read out on dash, but the warning light doesn't come on. So long story short, I've taken out the stock sensors and put those in the pressure canister. Warning like goes out.. out of my hair.. done
I had my winters on last week with no tpms and the warning light went on (flash first then stays on)
My OEMs are nowhere near where I park.
I did put them on for one week in September just to try them out, the light was never on. Although my daily commute was around 40km so less than 50mile according to SpecOne.
My winters are on a set of used EVO X BBS which i got from kijiji, so I suppose they would come with TPMS too.
Looking to get my 3is relearn the winter tpms, anybody know if I can get a tool to do it and which won't cost $800-$1000 according to my research?.
I'm not sure now really. There are a lot of people who got aftermarket ones to work, with proper pressure read out etc... but I(tire shop i went to) can't seem to, I'm starting to think it's their programing tool having some compatibility issues. Going to ask around the local shops and see if any one of them had more experience with this car.
Unfortunately those tools are all going to cost a great deal. But there are cheaper versions ($100)where you can pre-set 2 sets of TPMS IDs in there and just plug it into the OBD port to switch between your summer and winter set (once you have a tire shop get you the IDs for a one time fee). But you must find out if the sensors in the BBS' will work for the IS... not all of them are compatible.
Would you mind shine more lights on that?
I will try to get it done in the next 2 weeks and I can give you an update if it works for me.
Sensors read tire pressure relative to atmospheric, so if placed in a pressurized container the differential pressure across the sensor will always be zero.
lkapimp216
12-02-09 01:46 PM
