Uneven tire wear
Background: Picked up an L/certified 2014 Lexus with 29k miles in Feb, Here we are in Oct and I put on roughly 17k miles and the inside of the rear tires are worn out, need to replace them. Obviously I need an alignment, is the rear adjustable? If not adjustable kit avail? Should they have aligned it at the point of sale back in Feb?
On Amazon, search for, "Specialty Products 72450 LEXUS ADJ REAR CAMBER LINK" sold by Motospan.
Wear is a GOOD thing. You WANT wear. If you're not wearing, that means your car is performing like a Corolla. If you didn't want performance, this may be the wrong car for you.
Now if your alignment is WAY out of bounds because some component was bent, that's one thing. but if your wear is equal side to side, then it's just normal. You are supposed to consume tires every 15-25k miles on a performance vehicle. Ask any BMW owner.
i have the same problem with my tires!! the rear inner will always go out before the rest!! i have a full set of PSS coming in next week.
my currents tires are good on the on the outside, but the inner tire is bald!!!
dave197878
04-03-09 07:15 PM
