16 IS200T strange engine noise! help!
Old 01-21-19, 08:21 AM
  #46
E46CT
E46CT's Avatar
Received 2,218 Likes on 1,660 Posts
Originally Posted by EXE46
I have an issue with my IS200T. As of late, there's been a hesitation to accelerate. The other day, car completely shut down, luckily i was just moving from a stop light and going into a gas station. Car lost power, I slowly pulled in and Check engine light came on. Added some gas, checked fluids, all seem fine.Also, I only put premium grade gasoline in this thing. Car currently has less than 28k miles so it's not like service is due either. Restart car and it drove normal but it still has been hesitating to accelerate. I will take it in this month for the 30k Mile service and report to the service people. I made sure i took a video with the check engine on.
Would not recommend this motor to anyone, just get an IS350. Luckily my lease ends next summer and with Lexus pull ahead program I should be out of this car in May.
Are you 200T folks remembering to replace the spark plugs. If i'm not mistaken Lexus says they should be replaced at 30k. If you are tuned, half that.
I'm at 27k so far, original everything, no ill effects. I'll be letting the next owner (or dealer) replace the plugs though =D
Old 01-21-19, 10:01 AM
  #47
Sheddy
Sheddy's Avatar
Originally Posted by Max838
Have the same issue with that valve. So just curious where was it located before you placed it next to the dipstick
The valve is located on the intake manifold. See the diagram below with part number 25819.
DCT17 (01-01-24)
Old 01-21-19, 03:33 PM
  #48
EXE46
EXE46's Avatar
My car was loosing power and shutting off at around 27k. I bury my foot and it would go into limp mode and loose complete power, consequently had to shut down and restart. Lexus had to replace spark plugs and fuel injectors. This motor sucks, would not recommend. Stock motor, no mods but driven like I would my old BMW (not like your typical toyota driver).
Did toyota forgot how to build a good turbo motor?
Old 01-23-19, 12:04 PM
  #49
LouisV
LouisV's Avatar
Originally Posted by vanillatag
I have exactly the same noise issue, and it is indeed the vacuum valve regulator is making that noise. It seems this particular part is not very reliable. I am currently waiting for my 2nd replacement of this part.
The first time I had it replaced was around 10,000 miles. Now at 15,000 miles, the new part is making the same noise again. I just brought the car to the dealer last week and I am currently waiting for the replacement
other then the noise, how do you know you have the issue?
Old 01-23-19, 12:53 PM
  #50
Sheddy
Sheddy's Avatar
Thanks to CL member Patchez.
Old 01-27-19, 07:30 PM
  #51
hanomag251
10th Gear
hanomag251's Avatar
Could you tell us how you got to the valve? Its buried deep inside. Did you have to remove the intercooler overflow tank and hoses?
I might have to keep replacing it myself after the warranty expires.
Old 01-28-19, 11:21 AM
  #52
pngo
pngo's Avatar
Can anyone with experience with this failed part help me identify if the noise in this video sounds like it?
I hear an audible “chatter” noise but I’m not really picking up a fan noise.
Engine Noise Video
Thanks!!
Old 09-03-20, 10:03 PM
  #53
Lex_Giorgio
Lex_Giorgio's Avatar
Anyone had this issue on a 2017 model?
warmdye
04-27-20 11:28 AM
jdt
NX - 1st Gen (2015-2021)
11-20-17 04:55 PM
oldskewel
05-26-15 05:00 PM
noliesss
04-27-07 06:18 PM
doctorttt
07-20-06 12:58 AM
Quick Reply: 16 IS200T strange engine noise! help!
