IS 350 F Sport Staggered Wheel Question
Old 12-22-16, 04:25 PM
BED72055
BED72055's Avatar
Default IS 350 F Sport Staggered Wheel Question
First, I have searched the forums for a similar question, nothing found.
The front wheels are 18x8 and the rear wheels are 18x8.5 with two different tire sizes front and rear. My question is this: If I purchased a set of two 18x8.5 Lexus F Sport rear wheels and mounted the same size tires, 255-35-18, and mounted them on the front, would they fit without rubbing the inner fender wells or frame? I would prefer to have the same size wheels and tires front and rear.
I have seen several adds selling a complete set of four F Sport wheels and I thought I could use the wider read wheels on all four corners most of the time. I would then mount the smaller 18x8 front wheels with winter tires during the winter on all four corners. I would have two complete sets of wheels and tires but not the way Lexus designed it, wide wheels & tires for summer, narrow wheels & tires for the winter. All advice appreciated!
Brian - 2014 IS 350 F Sport
Old 12-25-16, 06:45 AM
Answer
Answer's Avatar
Rears won't fit in the front without spacers. And 255 in front will also mostly rub and make the steering harder to turn.
I'm running 245/40-18 up front for my summer setup and had some slight rubbing.
Old 01-04-17, 05:22 PM
BED72055
BED72055's Avatar
Thanks for the advice!
Old 01-08-17, 06:46 AM
Handi
Handi's Avatar
You could check by removing the wheels on one side and fitting your rear to the front.
Nothing better than actually mounting them up and taking some pictures.
beanders
11-19-16 03:43 AM
Celledral
10-18-16 01:47 PM
13GS
Wheels and Tires Classifieds
13
12-09-15 06:44 PM
silvaIS
10-26-14 08:34 PM
RadarB8
10-29-02 09:56 PM
Quick Reply: IS 350 F Sport Staggered Wheel Question
