IS250 Oil Change Parts Reference
2014-present Lexus IS250/IS250 F-Sport
Motor Oil Type: 0w-20 (5w-20 may be used, but subsequent oil change must be 0w-20 per Owner's Manual)
Max Oil Capacity: 2WD w/filter 6.6qt, 2WD w/o filter 6.2qt, AWD w/filter 6.8qt, AWD w/o filter 6.3qt
Toyota Oil Filter: 04152-YZZA3
Toyota Drain Plug Gasket: #12, 90430-12031
Tools:
Oil Filter Wrench: 64.5mm, 14 flutes
14mm socket for drain plug
10mm socket for 3 bolts on oil filter cover
Drain Pan with at least 7qt capacity
Floor Jack
Two Jack Stands (minimum 2-ton capacity)
Torque Spec:
28 ft lb for drain plug
Miscellaneous:
SmartKey Battery: CR2032
Toyota Engine Air Filter Element: 17801-31170
Wheel Lug Nut: 21mm deep socket, torque to 76 ft lb
Tire rotation: F-Sport models have different wheel sizes (cannot be rotated)
Tools:
Floor Jack
Torque Spec:
Miscellaneous:
rftuck
RX - 3rd Gen (2010-2015)
11-07-09 05:17 AM
