Drivers side door sometimes won't lock?
I have 2013 rx450h. driver door wouldn't lock or unlock with key fob or door button. I also couldn't roll down other windows from driver side buttons. first fix; reprogrammed all other windows except driver by starting car, then rolling down each one, continue holding down button for 3 seconds, then roll it up and continue holding button up for 3 seconds. did this on each of 3 other windows but not driver and it solved it.
driver door lock wouldn't work at all. if i pushed the button on key fob, nothing. if I pushed button on driver door panel, it twitched but wouldn't fully lock. looked at fuses, read manuals, rest door lock settings; nothing worked. my daughter got in passenger side front seat, told her what i was doing. she pushed the door lock button on front passenger door and it worked, locked all doors. And seemed to rest everything because now driver door works on both door button and key fob. only thing that doesn't seem to work now is touching indented part of door handle to lock doors after getting out. But I can deal with that by just locking door with button inside door as I get out, or with key fob. hope this helps someone and saves them hours i spent.
Because you have an RX, you might be better off posting in the RX Forums here: https://www.clublexus.com/forums/rx-...2010-2015-212/
The thread you're currently reading is in the IS forum.
