High Def LED Headlight and Check Mark LED Light
Hey everyone, I just left ijdmtoys and they didn't have any higher def for the headlights and check mark led light for the front of the car(2016 GS F Sport)...I'm in this forum because I saw a Lexus IS who had high def lights in those areas and I forgot the user name but it was a silver one(I know I'm being ambiguous with my description) Can anyone help me find out where I can obtain these??
The lights are all very much similar..please, any and all help is appreciated...
![](https://www.clublexus.com/forums/images/smilies/confused.gif)
Sounds like you're asking for 2014+ Lexus IS DRL (day time running lights)
https://www.lexuspartsnow.com/parts/...620-53030.html
https://www.lexuspartsnow.com/parts/...610-53030.html
376 new. 500 at dealer. or 150-200 on ebay used.
https://www.lexuspartsnow.com/parts-.../headlamp.html
the headlights can range from many different kind depending on the car. sounds like you're asking for the LED f-sport headlights which are the highest model. roughtly 700 dollar new. 100-200 used on ebay.
Lexus IS models came in halogen, HID and LED head lamps. Then it depends if it has auto level or auto high beams.
No, the Lexus IS and GS do not share the same headlights or DRL.
If your car is a 2016 GS f-sport, then it should have it's own DRL and Head lamps with HID or LED. why do you need them from an IS Model?
Your local lexus dealership can help you. Hope this helps.
if your car is an 2016 GS F sport then it does not have bulbs for the headlights. It uses LED headlamps that are not interchangeable. Also the DRL is also LED. Are you trying to change the bulbs? If so, you cannot do so. When you mean higher def, do you mean brighter? How bright do you want it because the head lamps LED are as bright as Legal as you can get. It's as bright as SUN light. 6000k.
I think you are looking for something like this.
http://ledheadlightsbulbs.com/lexus-...nversion-kits/
The color temperature are measured in Kelvin, so you can chose 8K for blue tint. I would have to say blue lights are really annoying to other drivers, and I despise them with the utmost hatred. And also illegal. But it's your car.
For brighter light output, you want higher wattage. Not sure what power consumption of the stock lights are but the one in the link ranges from 25W to 90W. But now you would need to worry about blowing fuses since it's drawing more current.
You have to find that out yourself tho. For the DRL, you can probably get a headlight tint/film to give it that 8k look.
It's possible that you have a single HID projector that uses D4S bulbs. that means you can swap out the factory bulb for this: http://store.ijdmtoy.com/Lexus-Toyot...id_d4s_d4r.htm
the hid kit is what I'm looking for but Lexus classifies it as LED...I called today and that's how they explained it to me. For what I need is the hid kit for the projector headlights and the led light check mark strip below it. That's all.
