Navi Update to V15A8910 skip the dealer
Old 11-28-19, 01:34 PM
  #46
Sasnuke
Sasnuke's Avatar
Received 1,738 Likes on 1,371 Posts
Originally Posted by Hardwinlex
I disconnected the negative terminal for at least 3 minutes. And the same thing happened. gets stuck on the caution screen. Do I have to disconnect the battery fully for 10 minutes (both the negative and positive cable)?
I would definitely recommend at least 10 minutes...several systems have capacitors that will retain power longer than 3 minutes...and take several minutes to discharge.
You only need remove the negative terminal...you can remove both if you like, but not necessary.
Old 11-28-19, 01:40 PM
  #47
Hardwinlex
Hardwinlex's Avatar
Okay I will try that out and let you know what happens.
Old 12-03-19, 12:43 PM
  #48
BJ350F
BJ350F's Avatar
Any updates on if this worked?
Old 12-03-19, 12:44 PM
  #49
BJ350F
BJ350F's Avatar
Does anyone have any updated links?
Old 12-03-19, 01:01 PM
  #50
Sasnuke
Sasnuke's Avatar
What vehicle are you looking for the update for? Do you know your current version in the navi unit?
Old 12-03-19, 07:08 PM
  #51
Hardwinlex
Hardwinlex's Avatar
https://drive.google.com/file/d/1Vn2...ew?usp=sharing
Keep in mind this is what I used to flash my navigation for my lexus gs 350 2015. It got stuck at the caution screen right after the update. I ended up replacing the whole radio after the update. Nothing could been done on the dealers end.
Just letting you know use this at your own risk.
Jazzrock (12-03-19)
Old 12-04-19, 06:09 AM
  #52
BJ350F
BJ350F's Avatar
Updating a 15 GS350 Fsport. My current version is V15A8840
Old 12-04-19, 06:52 AM
  #53
Sasnuke
Sasnuke's Avatar
@BJ350F I put the file in a Dropbox link as it's 89Mbs. https://www.dropbox.com/s/n66smomkfx..._0004.kwi?dl=0
This file is for 2015 GS350 with 12 inch Navigation. If you have the 8 inch non-Navigation in your car, this file is not for it.
Copy the file onto a USB stick, no bigger than 8GB, formatted to FAT32, and is USB 2.0.
Insert the stick into the USB port in the center armrest, and go to the Software Update section in the Navigation unit.
Old 12-04-19, 07:57 AM
  #54
BJ350F
BJ350F's Avatar
Thank you. Is this for this years version or last year?
Old 12-04-19, 08:00 AM
  #55
BJ350F
BJ350F's Avatar
Also your in Canada and im in The US. Does that make a difference? Or does it make a Difference that im in a GS vs a IS?
  #56
Sasnuke
Sasnuke's Avatar
The updates are to rectify performance issues with the unit...they have no impact on Map data. Map data can only be updated via replacement of the micro SD card.
If you were not having any performance issues with the unit and install the file I provided the link to, you will likely not notice any difference in the unit operation afterwards.
This file was produced sometime last year, and there have been no updates since. I presume this will be the last update released.
Old 12-04-19, 08:02 AM
  #57
Sasnuke
Sasnuke's Avatar
The update is dependent on unit software version only. Vehicle and country do not matter.
As my post above mentioned, this has no impact on Map data...it's only for the operating software.
Old 12-04-19, 08:14 AM
  #58
BJ350F
BJ350F's Avatar
Great man. Thanks for the info!
Old 02-26-20, 01:26 PM
  #59
Hardwinlex
Hardwinlex's Avatar
So just to follow up, I used Sasnukes download link for the Nav update and had no issues updating it.
Just beware towards the end of the update, the "caution screen" got stuck there for a few minutes .
But to fix that problem, I kept the flash drive in the usb after the update is completed and then drove the car around. and the Maps came on right away and was able to use all the Nav features.
Sasnuke (02-27-20)
Quick Reply: Navi Update to V15A8910 skip the dealer
