2014 is250 reliability
Coming from a euro car (03 20th gti) I really want my next car to be reliable and not having to worry about it breaking down. A new job requires me to drive everyday, I plan on buying a 2014 IS250 Fsport for 25k ish with 30-45k miles. I really like the Lexes and I'm either picking up the is250 for a CPO 2016 Gti. Can anyone tell me about the long term reliability of the 2014 is250 f sport(till about 100k)? I most likely will not be able to get it CPO because of my budget. Thank you for the help and your time!
Welcome to Club Lexus.
Lexus as a brand is rated one of the most reliable and dependable by many surveys:
http://www.consumerreports.org/car-r...they-stack-up/
http://www.jdpower.com/ratings/study...y-Make/1881ENG
As for the 2014 IS 250, the car ranks well for reliability and dependability as well:
http://www.jdpower.com/cars/lexus/is-250/2014
http://www.autoblog.com/buy/2014-Lex...0/reliability/
Google is your friend here as a search for "reliability of 2014 Lexus IS 250" will yield many informative results.
Make sure to differentiate preference ratings from dependability, as CR did not recommend this model for this year but this had nothing to do with the reliability, more for preferences like MPG rating and taste related issues like seating space, lack of power, interior layout, etc.
http://www.motortrend.com/news/2014-...eports-418623/
Good luck.
Good luck.
Keep in mind the 2.5L has issues with carbon build-up due to direct injection. The 3.5L has proven more reliable because it has both direct and port injection and its not that much worse on the gas. If you can swing it, the 3.5L is MUCH MUCH better.
Im pretty satisfied with mine at 20k miles. No issues so far!
I had two choices either is250 or is200t since I was in the middle of the refresh date.
It was either is250 grandfather engine with chance of carbon build up or is200t new engine lineup with possible initial issues.
In the end, I am happy with the is250 due to the throaty v6 sound rather than the is200t 4cyl honda civic sound.
I was in a budget also, so I was not able to consider the is350 at the time. BUT now if I had to redo my decision it would be IS350!
https://www.yourmechanic.com/article...y-maddy-martin
If you scroll down to the bottom, you'll see the IS250 on the top list of reliable cars. I have a friend in the market to replace a 2IS with a '14 IS250, probably looking one with the same mileage as you are unless she decides to lease new. There are issues with carbon build up on 2IS cars with the same engine, but time will tell on 3ISs. However, the IS250 still made that list.
BTW, just because you have/are considering a GTI and not just a regular Golf, I'd highly suggest looking into a 350 for the bigger motor and brakes.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Received 1,735 Likes
The reality is that carbon buildup can be an issue for any direct injection gasoline engine.
Lexus did develop a fix for the 2IS near the end of the model life, so those corrections should have been incorporated into the 3IS.
So...the 3IS 250 should be ok...and I say should cause my crystal ball is broken, so who knows what the future holds.
I wouldn't worry...it was really a 2IS issue and it didn't even affect every vehicle.
Vehicle usage was a contributing factor as well...can't blame the car altogether.
They fixed the carbon buildup on IS250 engine since 2012 IS250 model, 2006-2011 model uses 5-30W engine oil, 2012+ and up uses 0-20W, put an Oil Catch can in there and use only premium fuel and fuel injector once awhile, replace your PCV valve every 40k,
Sasnuke driving 2014 IS250 F-sport ?
i keep on forgetting to buy for my car but everytime im at Lexus dealership talking to those guys i forgot ! 12$ dollars CAD including tax ( PCV valve helps a ton )
